Author Topic: headlamp bulb  (Read 1885 times)
neilr
  • Barnet, Herts
headlamp bulb
« on: 24 October 2010, 19:25:16 »
how does the h7 main beam bulb come ouy. tried today anf failed managed to loosen relector though also tried to lamp out and didnt manage that either. what a day!
Re: headlamp bulb
« Reply #1 on: 24 October 2010, 19:29:50 »
It's just a clip that holds it in.
You loosened the reflector?  :-/ Does that mean you've broken the plastic adjuster? If your reflector is now loose & swivels up & down easily, I would think you have  :(
Search for ally adjuster replacement.
neilr
  • Barnet, Herts
Re: headlamp bulb
« Reply #2 on: 26 October 2010, 12:37:48 »
I saw clip with mirror bust coudnt work out how it releases anyone
Re: headlamp bulb
« Reply #3 on: 26 October 2010, 13:22:02 »
Each side of the clip is hooked under a hook either side of the lamp/bulb.
not an Omega & not quite the same, but the idea is the same.  :y
« Last Edit: 26 October 2010, 13:30:47 by Andy_B »
neilr
  • Barnet, Herts
Re: headlamp bulb
« Reply #4 on: 26 October 2010, 14:46:33 »
no hooks anywhere visible just looked like a ring. Are there any pictures any where.
Re: headlamp bulb
« Reply #5 on: 26 October 2010, 15:23:37 »
Ooops! It would've helped if I'd posted the picture to go with the blurb!  ::)
neilr
  • Barnet, Herts
Re: headlamp bulb
« Reply #6 on: 27 October 2010, 09:14:08 »
hi Andy thats what the H1 bulb looks like with the spring clip comes out easy. The main beam H7 bulb does not have that spring clip look just like a circular clip os some kind but I cant see how it comes of.
Re: headlamp bulb
« Reply #7 on: 27 October 2010, 09:22:54 »
Sorry. Wrong car  then. ;D Don't they just pull out, the clip bit being part of the headlamp itself, Mr Haynes says to 'Carefully press down the rear of the bulb, until it releases from its retaining clips'
neilr
  • Barnet, Herts
Re: headlamp bulb
« Reply #8 on: 27 October 2010, 17:43:55 »
yeah i read that too load of bo oops rubbish
Re: headlamp bulb
« Reply #9 on: 27 October 2010, 18:04:01 »
This is the ordinary main beam lamp you want to remove?
You're not sticking your tongue out far enough then. Just been out to the car, removed & refitted within a minute. As Mr Haynes says, push downward at the back, I left it plugged in, and it unclips quite easily.  :y :y :y
neilr
  • Barnet, Herts
Re: headlamp bulb
« Reply #10 on: 27 October 2010, 19:54:45 »
Thanks Andy I might try again tomorrow.Do you mean press the back of the bulb by teminals down towards the floor?
Re: headlamp bulb
« Reply #11 on: 27 October 2010, 19:56:35 »
Yes, as though you were snapping it off.   :y  :y  :y
which reminds me tha I didn't replace the black rubber cover on mine.  :-?  :y
« Last Edit: 27 October 2010, 19:56:51 by Andy_B »
neilr
  • Barnet, Herts
Re: headlamp bulb
« Reply #12 on: 27 October 2010, 20:00:40 »
Cheers Andy Ill give it another go the joys of the omega!
