Author Topic: Thermostat advice  (Read 1278 times)
skyblue
  • Bracknell
Thermostat advice
« on: 28 October 2010, 15:08:12 »
Think mine needs replacing as  the temp gauge seems to take forever to raise to the norm running temp. Drove for about approx 2 miles last night  to work before it even started to show a reading.  It didnt get up to norm running temp untill about 4 miles and by the time I reached  the hell hole  ( about 12miles ) it was up behaveing itself in some sort of fashion. Left her running while I had a smoke  in the car park and the fan cut in and did its job to bring the temp down.
This trip was without any heating on ( us midlanders are hard   ;D ) but the return journey home this morning I waited till she got up to temp before I put the heater on ( eco setting as I a thight barmaid) and that seemed to reduce the reading on the gauge a fraction and when I arrived home I left her running  and temp did raise up to just before fans  would kick in  before I switched  the engine off.
I have also noticed on colder days with the heating on  from the start of my journey the temp gauge will have no reading at all  for the whole journey hence why I think the stat is at fault.
I will be changeing  the coolant in the system as it appears to me to look weak and for a peice of mind aswell I want to be raedy for winter. So do ou think its a stat problem or am I looking for problems that arent there   :-? :-[
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
Re: Thermostat advice
« Reply #1 on: 28 October 2010, 15:21:45 »
Sounds to be the same as mine was doing last year about this time. Also notice mpg was down :-[ :-[. Had it changed and all fine get up to temp in about 5 mins now.
skyblue
  • Bracknell
« Reply #2 on: 28 October 2010, 15:58:14 »
thanks  SP for giving us the kick up the backside I needed .......parts ordered  from Vaux  for sat  operation  :y
Dave Elite
  • Ellesmere Port
« Reply #3 on: 28 October 2010, 16:07:09 »
When my stat was stuck open, the temp would sit at 75 on a run.
skyblue
  • Bracknell
« Reply #4 on: 28 October 2010, 17:09:50 »
Thanks Dave sounds like Ive ordered the right part then.... time will only tell I suppose  ;D
« Reply #5 on: 28 October 2010, 22:58:57 »
Easy way to check for a stuck open stat ...  start engine from cold and stand with a hand on the top water pipe .. the one from the stat to the radiator ....
IF the pipe very slowly warms up .. the stat is failed open.... what SHOULD happen is the pipe stays cold until the stat opens when you get a sudden "surge" of heat.
This check is faster to do if the heating is in the OFF position ....  :)
HTH  :)
« Last Edit: 28 October 2010, 22:59:43 by entwood »
