Author Topic: high temperature problem  (Read 1017 times)
itonks
  • Cannock, staffordshire
« on: 29 October 2010, 06:39:10 »
Hi on my way home from work this morning the temperature suddenly when right up and the warning light came on as I was on a dual carageway with no where to stop put in neutral and started to coast the temp then dropped and light went off so up in drive again and sure enough the temp started to rise again. ?? so did this to get me home
Checked water and oil when it had cooled down and found nothing wrong. Any ideas ??
Welung666
Re: high temperature problem
« Reply #1 on: 29 October 2010, 07:21:32 »
From cold take off the resevoir cap and check the coolant is clean. As long as it is start the car and check that there is a flow in the tank to check the waterpump is working. Were the fans kicking in?
itonks
« Reply #2 on: 29 October 2010, 16:07:40 »
water looks fine, no signs of any oil or anything, doesnt seem to be any water flow but will check water pump tomorrow. thanks
harpersimon
  • Marlow, Bucks
  • Live fast, Die young - leave a good looking corpse
« Reply #3 on: 29 October 2010, 17:08:54 »
Airlock possibly
Start car, cap off, heater on full heat, squeeze the rad hoses a few times when it starts getting warm.
Look up 'Burping' on here
« Last Edit: 29 October 2010, 17:09:22 by harpersimon »
