Author Topic: 2.2 Cam Chain  (Read 1398 times)
hughesy
2.2 Cam Chain
« on: 28 October 2010, 13:20:36 »
Hi all,
My first post here, so hello!
I'm going to look at a 2002 Omega 2.2 this weekend. I used to have a Vectra and I'm not actually looking for an Omega, they appear to be pretty good value for money. Anyway, when I had the Vec, I heard of the Cam Chain snapping on the 2.2 because of a problem with oil not lubricating the chain. Anyone know any more info about this and if this is something I can look out for?
Also, anyone want to give me some tips so I don't buy a complete dog?
Cheers!
Dave
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: 2.2 Cam Chain
« Reply #1 on: 28 October 2010, 13:24:57 »
No chain on 2.2 but belt and tensioners. find out when it was last changed from owner.
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: 2.2 Cam Chain
« Reply #2 on: 28 October 2010, 13:37:36 »
if the motor code starts with a z it will be chain (after 2001 i think) if it starts with a y it will be a belt, usually will have a sticker on the slam panel if it's belt for service intervals e.t.c. as to regards with the timing chain snapping i believe that was not on this motor but the se motor which didn't come out in the omega where as this would be a ev motor? as for checking for dogs i'm relatively new to omega's but if i was looking at one i would be checking steering straight braking e.t.c and ofcourse service history, most omega's have history as they are a fairly conservative exec car so if this is lost i would look deeper into it
« Last Edit: 28 October 2010, 13:48:38 by mrgreen »
Warning: Dates in Calendar are closer than they appear.
joshwyatt
  • Oxford
Re: 2.2 Cam Chain
« Reply #3 on: 28 October 2010, 13:56:23 »
All 2.2 petrol Omega's have a cambelt. The 2.2 DTI is a chain.
The cambelt along with waterpump should be changed every 40k miles or 4 years.
mrgreen
  • Salzburg/austria
Re: 2.2 Cam Chain
« Reply #4 on: 28 October 2010, 14:19:30 »
I stand corrected! :-[ so it's a mine field out there am i correct in thinking that the z motor is an alloy block as opposed to the y motor which is a cast block :question if not where lies the difference!
mathewst
  • Split, Croatia
    • v40
Re: 2.2 Cam Chain
« Reply #5 on: 28 October 2010, 15:10:23 »
The difference was in EURO norms y22 is Euro3 and Z22 is Euro4. Think only small difference was in ECU programming
Re: 2.2 Cam Chain
« Reply #6 on: 28 October 2010, 20:15:13 »
All Omega Petrols are belts.
2.2 and UK 2.5 diesels are chains.
All Omega belts are 40k, ignore any printed or verbal advice suggesting otherwise. For 2.0/2.2 do waterpump at same time.
hughesy
Re: 2.2 Cam Chain
« Reply #7 on: 28 October 2010, 21:52:17 »
Great thanks for the replies. I thought the 2.2 petrol was a chain!
Always found looking for cars such a ball ache. When I was looking for a Vectra a few years ago, all I heard was "Oh yeah it had a belt at 80k". Wrong interval and it didn't have the rollers/tensioners changed  >:(
Cheers!
Dave
Welung666
Re: 2.2 Cam Chain
« Reply #8 on: 28 October 2010, 21:58:26 »
Just to add to your confusion all the 2.2 petrol veccy's are chain ;D ;D
Re: 2.2 Cam Chain
« Reply #9 on: 29 October 2010, 17:47:22 »
Indeed, the Omega 2.2 petrol and the Vectra (and I think it went in some Astras/Zaffys) 2.2 are very different engines
