Author Topic: MV6 Springs  (Read 1448 times)
Marc Taylor
  • Essex
MV6 Springs
« on: 28 October 2010, 18:53:52 »
Hey everyone
I probably already know the answer to this but would standard springs from an MV6 fit on my 2.0 GLS or what would i need to change to make them fit?
Re: MV6 Springs
« Reply #1 on: 28 October 2010, 20:12:09 »
Yes, as long as both are Saloon or Estate.
Worth considering changing shocks at same time.
Marc Taylor
  • Essex
Re: MV6 Springs
« Reply #2 on: 28 October 2010, 20:18:17 »
thats good news as i have one spring snapped and only able to source mv6 springs, would it matter if shocks waited for a while?
Thanks for your reply
Mr Stud
  • somerset
Re: MV6 Springs
« Reply #3 on: 30 October 2010, 09:14:02 »
wouldn't the mv6 springs make the 2.0 sit higher due to engine weight difference between the two
biggriffin
  • huntingdon, Hoof'land
    • It's Insignificant
Re: MV6 Springs
« Reply #4 on: 30 October 2010, 09:18:26 »
wouldnt be noticeable as MV6 springs are lower.
Hoof'land storeman.
Re: MV6 Springs
« Reply #5 on: 30 October 2010, 09:38:14 »
Trade club lists all saloon mv6 (v engine) rear springs as "sport" same partt no. as 2.0 sport
Fronts are different part no. Mv6 lowered sport chassis on the v6...Sport for the 2.0' differant part no. to rear
So what they are saying is, saloon rears are the same, for lowered models, fronts are engine specific due to engine weight.
The estate mv6 however gets lowered sports chassis front and rear. The estate 2.0 sport gets sport front and rear....so estates have different part no. at the rear unlike the saloon....which seems odd to me.
Bet that clear as mud... ;D
Re: MV6 Springs
« Reply #6 on: 30 October 2010, 09:41:15 »
At the front yes it would be noticeable as you need the right springs at the front to match the engine weight.  :y
Welung666
Re: MV6 Springs
« Reply #7 on: 30 October 2010, 10:30:14 »
I have a pair of nearly new KYB 2.2 saloon rear springs here :y
Mr Stud
  • somerset
Re: MV6 Springs
« Reply #8 on: 30 October 2010, 19:48:42 »
At the front yes it would be noticeable as you need the right springs at the front to match the engine weight.:y
that's what i said :y
« Last Edit: 30 October 2010, 19:50:22 by Mr_Stud »
