Author Topic: cambelt change tool  (Read 1108 times)
mutleyman
  • thrapston, northamptonshire
cambelt change tool
« on: 01 November 2010, 20:44:21 »
help!! which locking tool  is best to use to lock crankshaft up. i got hold of the laser 3302 set but when i connected it up crankshaft timing mark and mark on oil sump housing they were not in line with each other.if i moved crank so that tool locked the marks were about 2 to 3 mm out.can you shim out the gap or can you put the belt on and tension it all up without using the locking tool. was looking  at the sealey vs130 but a bit pricey at £200
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
Re: cambelt change tool
« Reply #1 on: 01 November 2010, 22:57:05 »
well never done a belt on these but i can imagine if you're careful you shouldn't really need a locking tool.... i may be fully shot down for this but  i usually make marks where everything lies and line it all up on that afterwards but backyard mechanics may not apply here!!! ;D
Warning: Dates in Calendar are closer than they appear.
tidla
  • solihull
« Reply #2 on: 01 November 2010, 23:01:56 »
thats what happened to last to suggest such a thing ;D
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #3 on: 01 November 2010, 23:04:07 »
Unfortunately, it doesnt work.
The marks on the car are erroneous at best.
The locking kit should give you a better guide.  Buy the DVD from the OOF shop - It has all you need to do a belt change (provided you have a decent locking kit).
« Last Edit: 01 November 2010, 23:05:52 by Broomies_Mate »
« Reply #4 on: 01 November 2010, 23:04:44 »
Do not attempt cambelt change on a V6 without locking kit.  Other members have found the Laser kit to be inaccurate.  Best to sell it on on Ebay and look for a decent kit. ;)
« Last Edit: 01 November 2010, 23:05:06 by dbug »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 01 November 2010, 23:05:36 »
I have read on here that the Lazer Locking Kit doesnt fit properly... not sure where it doesn't fit properly though as I have a Pickervant one.
Usually lock it to the Crank, turn the crank clockwise until the slide locks onto the water pump, job done Crank is locked in position :y
I suppose the marks your talking about could be slightly out like the ones at the top near the cams on the backing plate :)
Please don't try and do the timing without using the locking kit, no matter what people tell you :y
« Last Edit: 01 November 2010, 23:06:26 by Loo-knee »
Welung666
« Reply #6 on: 02 November 2010, 06:15:58 »
Mutley, you are more than welcome to come up here and I'll help you with my kit :y
venom
  • South Moreton, Oxfordshire
« Reply #7 on: 02 November 2010, 06:48:09 »
I've just bought this set http://www.ldemporium.co.uk/engine-timing-tool-kit-for-v6-gmsaab-p-1626.html
but haven't used it yet but Welung666 got the same set on Sat and has used it 3 times already so he must think its OK  :y
Ken
« Reply #8 on: 02 November 2010, 08:52:17 »
Sadly not. You can get away with just a locking wedge on many twin cam engines, and nothing on many single cam engines, but the GM quad cam V6 definately needs a locking/timing kit. You cannot get the cam timing correct without, as it has infinate adjustment on it.
