Author Topic: Cooling fan coming on after every journey  (Read 1618 times)
Moopy37
« on: 27 October 2010, 10:57:31 »
Hi,
I've just purchased a 3.0L Omega Elite (2000).
I've notice that after pretter much every journer the radiator fan is coming on for around a minute after switching off the ignition. Furthermore, when the car has warmed up, the temperature seems to jump anywhere between about 88 and 94 degrees, is this normal?
Any help would be most appreciated.
smithpa7
Re: Cooling fan coming on after every journey
« Reply #1 on: 27 October 2010, 11:05:58 »
After a long journey my fan does come on for a minute or so. This is normal.
My temperature is fairly constant around the 89 mark. It may get hotter on a very hot day, then the fans will kck in to cool the engine. HTH :y
The varying temperature could be a faulty thermostat.
« Last Edit: 27 October 2010, 11:11:52 by smithpa7 »
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 27 October 2010, 11:10:15 »
Hi
Welcome to the forum.  My 2,5 V6 does the same thing with the cooling fan running after the car is switched off. I would say it is nothing to worry about,
Running temp is normal at about 95 deg I would say. Maybe you are seeing a big jump when the thermostat opens.
Good practice on the V6's is to have the right antifreeze mix using VX's red product. It wouldn't do any harm to let your coolant out and flush the system through to remove crud from the radiator unless it has recently been done.
Varche
« Reply #3 on: 27 October 2010, 18:39:39 »
My fans are alays on when I stop - the last mile through the town brings the temp up to fan threshold
« Reply #4 on: 27 October 2010, 18:43:37 »
Yes, as with mine it is perfectly normal for the fans to run, and those temperatures are as expected ;) ;)
Debs.
« Reply #5 on: 27 October 2010, 20:06:12 »
Mine also; when returning home, the steep up-hill crawl to the house always brings the two front-fans into life (at half-speed) and they continue for a few minutes after shutdown/key out. ;)
Rockhampton
  • Trecelyn, Gwent
  • Gone!
« Reply #6 on: 27 October 2010, 20:07:50 »
Yes, me too - even in the cold weather, they tend to remain on for a minute or so. Also the temperature variation, especially when in traffic, there is quite a range - nothing to worry about  :y
« Last Edit: 27 October 2010, 20:08:41 by rockhampton »
Previous GM Models include '00 Omega 2.5 CD Auto, '06 Holden Commodore Executive 3.6 Auto, '99 Astra 1.8 CDX Auto, several Astra Diesels.
Millerboy
  • Ellesmere, Shropshire
« Reply #7 on: 28 October 2010, 09:58:58 »
I'm quite pleased this has been brought up because mine does it also! All the time, even when it's cold out!
Todd
2woody
  • Northumberland
« Reply #8 on: 29 October 2010, 10:39:10 »
don't forget that it's a two-stage fan, the lower ( slow speed ) is not much above normal running temperature.
Moopy37
« Reply #9 on: 02 November 2010, 09:30:36 »
Thank you all for your help, I do get paranoid when it comes to cars.
shyboy
  • Southport, merseyside.
    • Mazda 6
« Reply #10 on: 02 November 2010, 09:44:54 »
Owning an Omega isn't going to help that at all!  ;)
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #11 on: 02 November 2010, 09:47:44 »
In fairness, the V6 does pump out a huge amount of hot air. My fans don't always kick in, certainly not now winter is closing in BUT when I get out I often get hit by a short blast of hot air....that said...sometimes I leave the wife at home  :) ;) :D
