Author Topic: auto gearbox  (Read 1229 times)
bert
auto gearbox
« on: 02 November 2010, 03:11:06 »
hi is there any images of the level filler plug as i would like to check fluid level i have read  how to do the job,images would be a great help cheers
Re: auto gearbox
« Reply #1 on: 02 November 2010, 08:48:10 »
I don't have any, but its pretty difficult yo miss a filler plug in the side of a sump :y
Jack it up, you'll find it :y
bert
Re: auto gearbox
« Reply #2 on: 02 November 2010, 15:20:12 »
thanks i,ll have a go :y
V6 CDX-er
  • Sheffield
Re: auto gearbox
« Reply #3 on: 02 November 2010, 23:37:12 »
Anyone know how much fluid the auto box holds? And does the diff take the same ATF as the auto box?
Cheers.
Re: auto gearbox
« Reply #4 on: 02 November 2010, 23:42:51 »
Cheers.
DON'T put ATF in your diff. I don't know off hand what goes in there but it'll be a hypoid SAE 80/90 .... ish
Kneepad
  • West Scotland
Re: auto gearbox
« Reply #5 on: 02 November 2010, 23:58:02 »
Cheers.
Automatic transmission (approximate):
From dry . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.4 litres
After removing main sump . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 4.4 litres
Final drive . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1.0 litre*
Renewal . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .  GM special lubricant 19 42 382 (9 293 688)
Top-up . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .  Hypoid gear oil, viscosity SAE 90
« Last Edit: 02 November 2010, 23:59:33 by Kneepad »
V6 CDX-er
  • Sheffield
Re: auto gearbox
« Reply #6 on: 03 November 2010, 01:36:19 »
Cheers.
Perfect. Thank you  :y
Is it worth buying the pre-facelift Haynes manual, even though mine is a facelift model? Are the mechanicals and running gear pretty much the same?
Re: auto gearbox
« Reply #7 on: 03 November 2010, 01:45:42 »
Cheers.
Yes :y
