Author Topic: Front Springs  (Read 945 times)
Marc Taylor
  • Essex
Front Springs
« on: 02 November 2010, 20:34:23 »
Im planning on replacing all springs in the next couple of days. Iv searched on here and back seems easy enough, im wondering how big a job are the front springs to do and how would i got about it.  I had a look and couldnt find a how-to for the fronts so any advice is welcome. Thanks in advance
Welung666
Re: Front Springs
« Reply #1 on: 02 November 2010, 21:39:40 »
Front shocks off, spring compressors on and release the top cap. That's the spring off. Reverse to re-fit. Have a look in the maintenance guide index for setting the camber HowTo but get it into somewhere like Wheels in Motion to get it set properly :y
symes
  • oxford
    • R reg 940 volvo
Re: Front Springs
« Reply #2 on: 02 November 2010, 22:43:13 »
If you mark around bottom of leg were the 2 bolts go through you wont need to reset your camber :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
Re: Front Springs
« Reply #3 on: 02 November 2010, 22:48:06 »
Marking the position of the components before removal will only act as a rough guide when re-fitting. Any work on the suspension can result in upsetting the suspension angles, also you need to factor in the ware rate of old suspension parts, ideally the car needs proper suspension alignment after any work is carried out......
Marc Taylor
  • Essex
Re: Front Springs
« Reply #4 on: 03 November 2010, 08:21:53 »
thanks everyone
