Author Topic: Basic water pump change  (Read 3273 times)
MutantCav
  • Gainsborough
Re: Basic water pump change
« Reply #15 on: 02 November 2010, 22:31:34 »
Not on the Sintra...wouldnt have thought the Omega was that different?? They are fiddly to get to with the cover on granted but not impossible :y
« Reply #16 on: 02 November 2010, 22:31:52 »
The Sintra which has an Omega(ish) engine you can change the waterpump by just removing the aux belt and undoing the 3 water pump bolts (as said dont drop them) and pulling out the pump...its fiddly though...there is a little more in the way of the Omega engine but still pretty straight forward :y
Water pump bolts are behind the cam belt cover though.
The hole in the cambelt cover is just big enough to get at the bolts  ;)
« Reply #17 on: 02 November 2010, 22:41:34 »
I'll stand in the corner corrected then.  ::) ::)
tidla
  • solihull
« Reply #18 on: 02 November 2010, 23:10:21 »
small hands reqd for cleaning the old gasket off..
« Reply #19 on: 02 November 2010, 23:28:44 »
no need,  it's an O ring located in a groove on the pump body, unless the bloke who fitted it used instant gasket too  ;)
tidla
  • solihull
« Reply #20 on: 03 November 2010, 00:21:31 »
is it an o ring on the thermo stat as well?
« Reply #21 on: 03 November 2010, 00:23:20 »
I've never even seen my 'stat, but I think so.   :y
« Reply #22 on: 03 November 2010, 08:58:38 »
Yep ;)
