Author Topic: Basic water pump change  (Read 3290 times)
tooleater
  • Rickmansworth,  Herts
    • Go faster Black MV6 Man
« on: 02 November 2010, 21:42:25 »
Anyone got a basic guide to changing a water pump on v6 2000 face lift,i have Haynes manual down loaded,but it seems to go into alot of detail..
Thanks John :y
Welung666
Re: Basic water pump change
« Reply #1 on: 02 November 2010, 21:44:34 »
Aux belt off, aux tensioner off, water pump pulley off, power steering pulley off, cam belt cover off, 3 water pump bolts off. Reverse to refit :y
tidla
  • solihull
« Reply #2 on: 02 November 2010, 21:47:07 »
my kind of manual :y :y
top up with loverly red antifreeze..
tooleater
« Reply #3 on: 02 November 2010, 21:51:58 »
Thanks for that, :ybut would you fit a QH pump or VX,i will use new bolts either way.
Cheers John
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #4 on: 02 November 2010, 21:55:27 »
can you write the next haynes manual so much better and easer  :) :) :)
Welung666
« Reply #5 on: 02 November 2010, 21:58:06 »
Not so important on a V6 as it's not cam belt drive so the QH will be fine and for the price you can change it every cam belt change anyway :y
Welung666
« Reply #6 on: 02 November 2010, 21:58:51 »
;D ;D ;D
It'd be about 7 pages long if wrote it ;D ;D
« Reply #7 on: 02 November 2010, 21:59:01 »
Follow the cambelt DVD, just dont change the belt.
You dont need new bolts but you will need a spot of loctite on the water pump pulley bolts.
Do be careful though as you are likely to give the cambelt a good drowning of coolant
tooleater
« Reply #8 on: 02 November 2010, 22:04:48 »
Thanks for that guys,still considering giving some one a £100 to do it,but they need to be mobile and GOOD :-/
john
MutantCav
  • Gainsborough
« Reply #9 on: 02 November 2010, 22:08:46 »
Depends where you are based mate, there are quite a few good people on here...worth updating your profile with location :y
« Reply #10 on: 02 November 2010, 22:11:50 »
You can change the water pump on the V6 without removing the cambelt cover, i've done it a couple of times now just don't drop the waterpump bolts ;)
MutantCav
  • Gainsborough
« Reply #11 on: 02 November 2010, 22:15:45 »
The Sintra which has an Omega(ish) engine you can change the waterpump by just removing the aux belt and undoing the 3 water pump bolts (as said dont drop them) and pulling out the pump...its fiddly though...there is a little more in the way of the Omega engine but still pretty straight forward :y
tooleater
« Reply #12 on: 02 November 2010, 22:17:57 »
 I am located in Watford Herts
Cheers John :y
tooleater
« Reply #13 on: 02 November 2010, 22:22:00 »
Cheers guys for info,logging out now Boiler rip out to do tomorrow.
John
  • Online Online
« Reply #14 on: 02 November 2010, 22:22:51 »
Water pump bolts are behind the cam belt cover though.
« Last Edit: 02 November 2010, 22:23:11 by Andy_B »
