Author Topic: Blower Stopped Working  (Read 2525 times)
unitfour
« on: 17 October 2010, 15:22:14 »
I have a 2003 MV6 3.2 Estate. Last night the blower just stopped working, every thing on the dash and heater controls are working ok but no blower. Any ideas? fuses, relays etc. just seen on this site re the blower speed control is behind the glove box. Going to look at it now, Any help would be greatly appeciated, Otherwise its a trip to Vauxhall main dealer for a whacking bill !!!!!!!!!!!!!
Re: Blower Stopped Working
« Reply #1 on: 17 October 2010, 15:28:47 »
Check fuse #33 under steering wheel, big one top L/H corner IIRC
unitfour
« Reply #2 on: 17 October 2010, 15:34:43 »
fuse 33 Green 30 Amp is intact.
unitfour
« Reply #3 on: 17 October 2010, 16:34:30 »
just got the glove box out and can see the blower and speed controller, anyone Know how to get to it or have i got to take the whole dash out?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #4 on: 17 October 2010, 19:37:29 »
You dont have to take the dash out to get to the controller but it is a very fiddly job which needs 3 hands . I tried to remove one and broke both plastic retaining clips this was when the temperature was zero but be very careful if you decide to remove it
Steveplumb
  • Radstock, Near Bath
« Reply #5 on: 17 October 2010, 19:45:46 »
Mine used to just stop , try giving it a spin by hand , I also sprayed WD 40 around the spindle hoping it would seep into the bearing. It seems to have done the trick  .....  The only thing you need to remove is the section above the passenger foot well , 3 fixings screw i think . Select recirc that opens access to the drum type fan .  Reach up top left.  good luck . I hope it works for you too
Kerry B
« Reply #6 on: 17 October 2010, 20:26:04 »
not sure if same problem as yours with the speed controller, mine won't stop, i have to take the fuse out otherwise it runs on full even with the ignition key out! must get fixed before mot, due end of the month but no major worry as don't need mot on the island, just tax and insurance great if you don't want to go to Tesco or Co-op!!! Good luck getting yours sorted
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 18 October 2010, 22:40:52 »
Blower wont stop yes regulator needs changing I had the same problem
omegadti
  • Glasgow
    • omega dti
« Reply #8 on: 19 October 2010, 22:56:33 »
seems to be the time of year for the heater to pack up - my fan stopped working today - looks like it is a common Omga fault by the number of members suffering this week!!
« Reply #9 on: 30 October 2010, 01:13:47 »
So how do we fix it..... :)
omegadti
  • Glasgow
    • omega dti
« Reply #10 on: 31 October 2010, 22:36:08 »
bought a second hand unit and had it fitted - now have a fan and heat......but only on low speeds.....on full blast the thing is vibrating like mad....waiting for replacement to arrive in post but at least I know it iwas the fan that was seized
« Reply #11 on: 03 November 2010, 21:18:57 »
New rheostat / controller fitted and fan all up and running now...... :y
