Author Topic: door courtesy lights not working?  (Read 1489 times)
bestie26
  • bradford , west yorkshire
« on: 04 November 2010, 23:15:21 »
does anyone know what fuse to check for for the door courtesy lights or whatever they are called, ( the lights to alert passing drivers that your door is open) the lights are there but not working ? are they meant to work as its only a basic glsi spec facelift model or is it not a posh enough model  for them to work ?
Re: door courtesy lights not working?
« Reply #1 on: 04 November 2010, 23:20:12 »
Should work. Check fuses #12 & #20
« Reply #2 on: 04 November 2010, 23:20:41 »
 ... the door courtesy lights or whatever they are called, ( the lights to alert passing drivers that your door is open) the lights are there but not working ?  ..... [/quote]
Puddle lights  :y :y
no idea on where they're fed from  :-/
« Reply #3 on: 04 November 2010, 23:23:12 »
If you mean the lights in the door cards ... the "semi-official" name  ... is "puddle lights"   :)
It's easier than the "official"...  LAMP, ASSY., DOOR, INNER, FRONT
If memory serves they come off the door switches which are "double"  .. one for the "normal" internal light, one for the door light .. but they are a tad weird ...  on my car .. both fronts work from the drivers door .. but only the drivers side works from the passenger door !!!  and I can't find out why !!! Even tried swapping the switches over ... :(
« Last Edit: 04 November 2010, 23:26:24 by entwood »
bestie26
« Reply #4 on: 04 November 2010, 23:24:15 »
puddle lights , thats easier to say  than my description :)
ill check fuses tomorrow
cheers
« Reply #5 on: 04 November 2010, 23:32:14 »
If memory serves they come off the door switches which are "double"  .. one for the "normal" internal light, one for the door light ..  .....
Just the front door switches are twin contacts, the rars are single .................. according to Mr Haynes  ;)
« Reply #6 on: 05 November 2010, 01:04:54 »
Bulbs? :-/
bestie26
« Reply #7 on: 05 November 2010, 01:36:29 »
ill start with the fuses i think and go from there , not really an issue just a niggle that the lights are there and not working
cheers
skyblue
  • Bracknell
« Reply #8 on: 05 November 2010, 11:23:05 »
Have a look a No 7 fuse ..... this is the one that I needed to change when I had the same problem and I pull it if I need to have the doors open over a long period of time.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #9 on: 05 November 2010, 12:40:53 »
The rear door switches from my Omega were twin pole, I know this because they now live in the rear of my Vectra to run the kerb lights...
« Reply #10 on: 05 November 2010, 14:19:54 »
Track 460 - 465 show the door switches, but you are correct, the rears are twin contact too - I've just looked at my car.  :y :y
