Author Topic: strong vibration from clutch pedal  (Read 2035 times)
chuftsmv6
  • stoke on trent
    • omega mv6 2jz and audi s3
« on: 05 November 2010, 19:46:09 »
hi there i was wondering if anyone could help . i have a vibration coming from my clutch pedal when its fully out is this normal  :)i have a omega mini facelift mv6 3.0v6 1998 manual and i also have a juddering in first gear when i pull off i replaced the clutch  about a year ago and it started about 500 miles after i fitted the clutch  any info would be great thanks
Omegatoy
  • UK
Re: strong vibration from clutch pedal
« Reply #1 on: 05 November 2010, 20:33:09 »
oh oh!!! sounds like DMF but cold just be a recon clutch rather than a new one? vaux had a batch of bad ones around that juddered like billyo!! thought that had been sorted though
chuftsmv6
  • stoke on trent
« Reply #2 on: 05 November 2010, 20:37:52 »
hi dont want to sound daft but what does dmf mean thanks ;D :)
chuftsmv6
  • stoke on trent
« Reply #3 on: 05 November 2010, 20:41:56 »
do you mean dual mast flywheel im a bit slow at times haha ;D ;D :)
Welung666
« Reply #4 on: 05 November 2010, 20:43:00 »
Yes, Dual Mass Flywheel :y
Omegatoy
  • UK
« Reply #5 on: 05 November 2010, 20:43:48 »
nearly right!! ;D
chuftsmv6
  • stoke on trent
« Reply #6 on: 05 November 2010, 20:45:22 »
thanks if it is the flywheel is therere any normal solid flywheels that will fit because i think the dmf is quite exspensive. thanks for the help ur a star  :) :) :y
Welung666
« Reply #7 on: 05 November 2010, 20:46:23 »
thanks if it is the flywheel is therere any normal solid flywheels that will fit because i think the dmf is quite exspensive. thanks for the help you are a star  :) :) :y
Around £150 from buypartsby.com :y
See the correction below  :-/
« Last Edit: 05 November 2010, 20:55:54 by Welung666 »
chuftsmv6
  • stoke on trent
« Reply #8 on: 05 November 2010, 20:49:08 »
thats alot cheaper than m dealers i think they wanted 1000 for one i nearly past out when he said. thanks for the help.  ;D ;D :y :y
Omegatoy
  • UK
« Reply #9 on: 05 November 2010, 20:50:48 »
courtenay used to do a solid flywheel conversion? not sure if its still available but it was more expensive than a buypartsby dmf!!
chuftsmv6
  • stoke on trent
« Reply #10 on: 05 November 2010, 20:53:41 »
il have to strip it down and have a good look then thanks again for the advice its helped alot  :y :y
Welung666
« Reply #11 on: 05 November 2010, 20:55:11 »
Good job I checked as the price above is incorrect :( Sorry...
From the buypartsby.com website...
Part Number : 415003710
 Cost : £210.10 + vat
 Dual Mass Flywheel
 Model: Omega 3.0 V6
 Year range:  04/94-
 Extra info:  Dual Mass Flywheel
 Plate Dia: (mm) X30XE
chuftsmv6
  • stoke on trent
« Reply #12 on: 05 November 2010, 20:59:57 »
thats abit higher. at least its a lot lot lot  less than the m dealers thanks again  :y :y
