Author Topic: 2.2 auto box problem  (Read 1226 times)
gbaker
« on: 07 November 2010, 23:33:57 »
Hi just a quick one we have a 2.2 auto that has an intermitent fault which is when you start the car put it in drive sometimes selects 4th and not 1st but will drive in manual selection and another time you can start select drive and away you go no problems also the sport mode does not work ,i have been told a few things like ecu ,gear stick,but thought i see what you good people suggest many thanks Graham
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: 2.2 auto box problem
« Reply #1 on: 08 November 2010, 07:15:42 »
You need to get the codes read by a TechII to be able to diagnose the problem properly.
Where abouts are you?
I like red cars
2woody
  • Northumberland
« Reply #2 on: 08 November 2010, 10:11:34 »
sounds like a failed or failing position switch.
try taking it off and drowning it in WD-40 - it's located on the side of the transmission, covered by a thin steel cover. Look for the electrical connection.
« Reply #3 on: 08 November 2010, 10:24:30 »
Yep. Worth checking that the indicator LEDs by the stick follow its' position accurately without jumping about as these utilise the same switches as the gearbox ECU. :y
While the switch is off, check the linkage is adjusted correctly.
Failing that, check the engine and gearbox ECU for trouble codes. It's not unheard of for an engine problem (e.g. crank/cam sensor) to cause an erratic RPM input to the gearbox ECU which causes it to go into limp-home. Does the engine always start OK, out of interest?
Always worth checking the ATF level and condition, and, if it hasn't ever been changed, drop the sumps and replace the fluid. The fact that it is intermittent and drives OK manually makes me thing it's an electrical issue though.
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #4 on: 08 November 2010, 10:25:46 »
As already said, selector switch would be a good place to check first. :y
http://www.omegaowners.com/forum/YaBB.pl?num=1267956397
Manual gears can be selected OK as you have chosen which gear to be in whereas in drive the selector has to choose which gear to be in. Will sometimes go into ' limp home' mode, hence the higher gear selection.
ajn
  • cardiff
« Reply #5 on: 08 November 2010, 21:07:10 »
ello i had this problem when i took the selector switch off(side of gearbox) two of the contacts were snapped bought another selector switch from one of the forums fitted it no problems since  :y hope this helps ajn
« Last Edit: 08 November 2010, 21:08:42 by ajn »
gbaker
« Reply #6 on: 08 November 2010, 23:22:44 »
well what can i say many thanks guys i will try what you have said thanks again  :) :y
