Author Topic: Help - i think the inevitable has happened!!  (Read 3490 times)
markm730
  • Oldham, Northwest
« on: 08 November 2010, 09:48:21 »
After droppin my lad off at school this morning ive pulled up outside the house and have lost all drive.
2.5 auto, none of the gears will engage and the park brake wont work either. engine turns over fine and as normal but just dont have any drive.
have been having problems with what could possible be worn bearings in the diff - see previous posts for details.
have breakdown recovery on way out shortly to see if they can pinpoint the prob but for now does anyone have any ideas???
2woody
  • Northumberland
Re: Help - i think the inevitable has happened!!
« Reply #1 on: 08 November 2010, 10:08:46 »
check that the lever hasn't fallen off the auto gearbox shifter. The one from the base of the lever to the actual transmission.
for a diff to become so worn that it loses drive, it'll have been making noises loud enough to wake the dead for tens of thousands of miles IMO
markm730
  • Oldham, Northwest
« Reply #2 on: 08 November 2010, 10:23:49 »
well what can i say apart from a "certain colour of flag" breakdown are a waste of time. just had them out now and he sat in the car, moved the gear lever up and down a few times and said "it could be this or it could be that" im not 100% sure but i can take you to a garage and even if it was a gearbox problem i cant do anything at the side of the road!!
Thanks for nothing - he certainly earning his wages today!!
im getting it down to the local garage this afternoon so will mention the point about the gear lever, thanks for that.
cheers
mark  :y
2woody
  • Northumberland
« Reply #3 on: 08 November 2010, 10:25:08 »
or try the big "what gear am I in" switch on the side of the gearbox.
does the idle change when you move the lever - like it has gone into gear ?
markm730
  • Oldham, Northwest
« Reply #4 on: 08 November 2010, 10:39:21 »
no change at all in idle speed when gear selected.
whats the switch your on about?
« Reply #5 on: 08 November 2010, 10:43:30 »
[edit]
or try the big "what gear am I in" switch on the side of the gearbox. .....
[/edit]
you have to get under the car to see it.  :y
markm730
  • Oldham, Northwest
« Reply #6 on: 08 November 2010, 10:50:30 »
not being a mechanic and also not wanting to sound stoopid - probably too late for that!, what does this switch do?
« Reply #7 on: 08 November 2010, 10:51:52 »
electrically confirms that you are in the gear selected.
Have a read through this ...... http://www.omegaowners.com/forum/YaBB.pl?num=1267956397 they're expensive to replace with a new one, but apparently generally respond to a clean.  ;) :y
« Last Edit: 08 November 2010, 10:54:29 by Andy_B »
markm730
  • Oldham, Northwest
« Reply #8 on: 08 November 2010, 10:58:36 »
ok thanks,
failing that, do you think it could be anything else?
is it possible it could of had something to do with the noise ive been getting from the rear end over the last few mths?
possible diagnosis from previous posts all point towards the diff / driveshaft.
thx
« Reply #9 on: 08 November 2010, 10:59:28 »
Do the gear selector lights move in conjunction with the gear lever position?
Ie does the neutral light coincide with neutral gear lever position,same for drive, and so on for all gears...?
« Reply #10 on: 08 November 2010, 11:03:28 »
thx
Now that you mention that particular symptom ......  ::) could be!
Try Bury Salvage, he had a few Omegas in a few months ago if you need bits,
http://maps.google.co.uk/maps/place?hl=en&um=1&ie=UTF-8&q=bury+salvage&fb=1&gl=uk&hq=salvage&hnear=Bury,+Greater+Manchester&cid=11983036529691141666 or Auto Save around the corner is a good yard, no idea what he has in at the moment though.  :y  :y  :y
« Last Edit: 08 November 2010, 11:05:35 by Andy_B »
markm730
  • Oldham, Northwest
« Reply #11 on: 08 November 2010, 11:07:37 »
just checked now, yes all the lights correspond with the relevant gear selection  :y
Welung666
« Reply #12 on: 08 November 2010, 11:23:36 »
I've got a diff if it does turn out to be that :y
markm730
  • Oldham, Northwest
« Reply #13 on: 08 November 2010, 11:33:26 »
been onto bury salvage and they have a w-reg 2.5 in and wants £100 for the diff or £30 for the d/shaft although he didnt say if it was an auto or not - will this make a difference and is this an ok price to pay for these parts if thats the prob?
i did get a reply last week from someone who had a diff going but they wanted £70 i think but then it would have to be posted coz i cant get to it and the garage wants £100 for fittin it.  :'( :'(
« Reply #14 on: 08 November 2010, 11:34:07 »
So, presumably, if engine running and box in drive, the prop will turn but the drive shafts and wheels will not.
Can the prop be seen turning under the car?
« Last Edit: 08 November 2010, 11:34:25 by chrisgixer »
