Author Topic: P1590 Fault Code  (Read 2003 times)
Boditza
  • Craiova, Romania
P1590 Fault Code
« on: 09 November 2010, 07:24:37 »
I have this fault code but i don't know how to get rid of it.. it says Engine running signal low but what does it talk about??
Kneepad
  • West Scotland
Re: P1590 Fault Code
« Reply #1 on: 09 November 2010, 09:32:17 »
Check code again, it does not appear to be a valid code.
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #2 on: 09 November 2010, 09:43:21 »
Yes it is, it may be to do with the speed signal sensor in the vp44 fuel pump...
Boditza
  • Craiova, Romania
« Reply #3 on: 09 November 2010, 10:34:29 »
and where is that?? it also starts a little slow.. it revolves the engine 2-3 times before it starts. can you please post some pics.
Kneepad
  • West Scotland
« Reply #4 on: 09 November 2010, 11:31:27 »
Interesting, don't see it on the OOF fault code list.   :-/
Boditza
  • Craiova, Romania
« Reply #5 on: 09 November 2010, 12:07:49 »
they are present in autodata ;)
This is what i could get out out of tis 2000
B-001      DIAGNOSTIC TROUBLE CODE
P1590      Engine Running Signal Low Input
Short to ground or interruption in circuit to control unit terminal 39
Concerned Terminals:
1, 2, 39
Work Order Description
Ignition OFF
Disconnect wiring harness connector from:
Diagnostic tester
Ignition ON
Engine running at idle speed, operating temperature
Increase engine speed to 3000 rpm
Measure voltage between the following terminals:
Battery Voltage (Positive Terminal)
Ground
  nominal value 13.5 ... 14.5 V
if above are not true then : Defective component: G2 Alternator ; if they are true then
Ignition OFF
K70 Control Unit - Diesel
(Wiring Harness Connector 81P )
Ignition ON
Connect test lamp ( 55 W ) and multimeter in parallel and measure voltage between the following terminals:
Wiring harness connector (wiring harness side) terminal 39 (81P)
Ground
 Nominal Value   greater than 11 V
if above are not true then:
High transition resistance between:
S1 Switch - Starter
Wiring harness connector (wiring harness side) terminal 15
and if true
Work Order Description   Nominal Value
Wiring harness connector (wiring harness side) terminal 1 (81P), 2 (81P)
nominal value:  greater than 11 V
if these are not true either then :
G1 Battery
Wiring harness connector (wiring harness side) terminal 31
but if true
if someone knows the wiring and what joints i should check please post some pics here so that i can see where to check because my hunch is that is a non-perfect contact somewhere but i don't know what g2 k70 etc are
« Last Edit: 09 November 2010, 12:43:22 by boditza »
