Author Topic: Broken Keyfob Help needed  (Read 3630 times)
2camjohn
  • Manchester
« on: 06 November 2010, 17:37:38 »
Hi Guys
Sorry if this has been posted before. I searched but couldnt find anything.
The Keyfob on my X reg Omega CDX (2.5 6 cylinder turbo diesel) has been a bit unreliable recently.
So I gave it to a friend to fix and he broke the little circuit board inside completely  >:(
I understand its over £100 to get a new key from vauhall. Is that my only option? Or is there some way I can replace it for cheaper.
Ive set the alarm on silent so I can still use the car for now but the sidelights still flash. Is there any way I can stop that?
Cheers guys.
Hope someone can help me in my hour of need.
John
Re: Broken Keyfob Help needed
« Reply #1 on: 06 November 2010, 17:40:32 »
Hi Guys
Cheers guys.
John
Facelift 3 button fob is £27 + VAT. If you are near http://theboy.omegaowners.com that is likely to be the cheapest programming around ;)
(I should add, in the spirit of fairness and openess, that link is to my site).
« Reply #2 on: 06 November 2010, 17:42:09 »
Ive set the alarm on silent so I can still use the car for now but the sidelights still flash.  ....
Hi. Welcome to the forum.  :y
Silent mode on the alarm  :-/ you mean you've unplugged the siren? Cos the alarm does/shouldn't have a silent mode.  ;)
Sidelights flashing, you mean indicators.  :-/
If you update you profile, it might be that there is someone local-ish to you that could programme you a new fob.
« Reply #3 on: 06 November 2010, 18:18:28 »
Get fob only from dealers parts dept. ...do NOT go into the service dept, they will tell you its no good if not programmed. £35 new, get THE BOY to prog, via his site then fit your key blade and immobiliser chip to the new fob.
He did mine and others, saved a fortune.
For info, the case and buttons are available from gay bay as a kit for £15 odd. Buttons easily soldered in as a Kevin Wood showed me last week. But as your inards are broke it's dealers for you.
Key, car pass numbers, car, and tech 2 all need to be present for programming fob etc.
And welcome btw.  :y
2camjohn
  • Manchester
« Reply #4 on: 06 November 2010, 20:50:27 »
Wow thanks for all the replies and welcomes. Lots of options already  :D
The key part is fine but the circuit board with the buttons on it is totally broken and the case has seen better days.
So its £35 + £20 to program it. Thats A lot more like what I want to spend.   :)
Im in Manchester so I guess that TheBoy is quite far away.
Anyone close to me I can try?
« Last Edit: 06 November 2010, 20:50:48 by 2camjohn »
« Reply #5 on: 06 November 2010, 21:15:04 »
Sorry. I know that the bloke from Polar Air Con http://www.polar-aircon.co.uk/  has a real Tech II ..... whether he can use it  ::) No idea of his prices I only know he has it cos he's done a/c on my car & I spotted it in his van.
chrism551
  • sunny blackpool
« Reply #6 on: 06 November 2010, 22:55:20 »
how do you go on if you dont have the pass numbers for the car
« Reply #7 on: 06 November 2010, 23:18:51 »
then you need to buy a Car Pass from your local friendly dealer. They cost anything from around £25 to £silly
Martin_1962
« Reply #8 on: 07 November 2010, 14:08:24 »
How is it broken inside - post a picture
« Reply #9 on: 07 November 2010, 21:05:11 »
And welcome btw.  :y
Only the silly arse put the cheap switches in his, and the more expensive ones in Monkey-Nuts fob.  Hope they give you an extra pickle tray next time you visit ;D ;D
2camjohn
  • Manchester
« Reply #10 on: 08 November 2010, 14:57:23 »
Plated holes ripped out of the board.
About 9 tracks peeled off.
Its very broken.
2camjohn
  • Manchester
« Reply #11 on: 08 November 2010, 14:58:00 »
Thanks Ill give him a try.
Any other recommendations?
« Reply #12 on: 08 November 2010, 15:22:39 »
How else can the cheap ones be adequately tested than being on my err... spare... er.. fob that sits in a drawer.... Anyway, moving swiftly on... ::)
« Last Edit: 08 November 2010, 15:23:35 by Kevin_Wood »
Dave Elite
  • Ellesmere Port
« Reply #13 on: 08 November 2010, 15:30:24 »
Where can you buy the switches from?
unlucky mark mv6
  • tipton,west mids
« Reply #14 on: 08 November 2010, 22:38:43 »
While we are on the subject of key fobs,i have to press mine really hard most of the time to get it to work properly.Is there an easy fix for this at all. :-/
