Author Topic: Check Control: Attention!! Check Oil Level  (Read 2974 times)
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
« on: 10 November 2010, 16:17:18 »
Over the last two days check control, via my CID, has kindly informed me that I should check my oil level, which I did this morning.
I found it was halfway between MIN and MAX, so time to top up a bit, which is something I've never had to do to date.
Question is, is check control set to kick in earlier than the dashboard oil light (and if that came on I assume I would be at MIN or less) and is coming on at halfway about right?
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Check Control: Attention!! Check Oil Level
« Reply #1 on: 10 November 2010, 16:23:11 »
dashboard oil light is oil pressure low warning
other rides
« Reply #2 on: 10 November 2010, 16:25:57 »
The dashboard oil light indicates low oil pressure, not low oil level. ;) If that comes on, you need to stop the engine immediately as it's no longer being lubricated.
The low oil warning does indeed come on before you reach the low mark on the dipstick under some conditions (and may not come on with oil level below minimum in others).
The warning is a useful indication that the oil level has been overlooked but it's not to be relied upon. Nothing beats a check of the dipstick every now and then. :y
Mr Hagon
  • South West London
« Reply #3 on: 10 November 2010, 16:45:09 »
Marvellous, thanks for the clarity on the difference between the check control and the dashboard light.
I will monitor the oil level regularly now to see if it's developed a thirst for oil or just needs a one-off top up.
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
« Reply #4 on: 10 November 2010, 17:41:07 »
I have had the check oil light on only once in 9 years and that followed a period when I was doing a lot of miles over a short period of time. Like you oil did not seem too low but topped up to max and that was the end of it. Then back to normal - i.e. no oil usage between services effectively but it does get down to half way between max and min. As said keeping topped up is best policy.
dbr
  • north east.
    • 1997. 2.5CD petrol
« Reply #5 on: 10 November 2010, 19:17:43 »
I always find long motorway runs cause the oil to burn....1000ml+, so I keep a litre in the tyre well. Dash warning always comes on 1/2 between min + max
Mr Hagon
  • South West London
« Reply #6 on: 10 November 2010, 22:45:15 »
Thanks all for the advice.  I checked the level this morning when the engine was cold, but reading the manual it states that this should be done five minutes after the engine has been switched off.
Is this likely to change the reading I get on the dipstick?
« Reply #7 on: 10 November 2010, 22:52:06 »
Yes .. by quite a bit.  If the engine has "stood" overnight the oil will have "drained" down from the galleries and surfaces it is supposed to coat. Therefore the level in the sump will be higher than it should be. It will therefore "over read".. :(
Some folks think that the fact the oil is cold, rather than warm will correct this .. but the co-efficient of expansion of oil as it warms up is actually very small.
Either way, the manufacturer gives a set of "datums" ... the marks on the dipstick, the type of oil, and an indication of when to check it .. all in order to ensure the level is "correct"
HTH  :)
Mr Hagon
  • South West London
« Reply #8 on: 10 November 2010, 22:56:32 »
HTH  :)
Check control didn't alert me on the commute today in either direction, but I will have to take a look tomorrow when I get to the office as it will be light by the time I arrive, compared to when I get home  :).
However as the engine currently has 5w30, what implications does that have?
Bionic
  • Leicester
  • Why drive anything else?
    • 1999 F/L 3.0 Elite saloon
« Reply #9 on: 11 November 2010, 03:22:10 »
The only oil you should be using is what is recommended by VX/GM - GM's own brand 10w40 Semi Synthetic. It is all I use now since its recommendation by DarthLooKnee and now I never have any mayo in the oil filler neck whatever the weather. It is cheap to buy at the (dare I say it) the stealer dealership too. Cheaper still with a trade card. Same applies to the antifreeze seeing as it is now that time of year again.
 :D
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #10 on: 29 January 2013, 19:14:52 »
Mine has started coming on with alarming regularity twice in the last 3 weeks the level seems fine and no traces of oil in the header tank . But I have got a lot of mayo in the filler neck my car is missing the under tray so I would see any drips or leaks just wondering if its the sensor playing up ?
2001 MV6 3.2 manual been converted from 2.6 auto
« Reply #11 on: 29 January 2013, 20:39:22 »
 :D
Look in your handbook mate - 5w30 is one of the oil viscosities recommended by Vx.  Have to say though have always used GM's own brand 10w40 Semi Synthetic in our Omegas as its cost effective on TC compared to Vx fully synthetic.
Do use Vx fully synthetic in the Jag though (good price on TC!) ;)
« Reply #12 on: 29 January 2013, 21:16:33 »
5w30 fully synthetic is the ONLY oil specified for the later 2.2, 2.6 and 3.2 cars.. That came in with the silly 20K oil change interval. In practice, it doesn't really matter if an appropriate oil change interval is used, and I wouldn't leave any oil in for 20k. :o
Andy89
  • Norway
    • 97 3.0 MV6
« Reply #13 on: 29 January 2013, 22:04:47 »
There is 2 different messages on oil level, one that says you should check the oil level, and another that says low oil level  :P
yeah my engine uses a bit of oil  :-\ good thing a reconditioned is going in soon
« Reply #14 on: 29 January 2013, 22:12:18 »
There is 2 different messages on oil level, one that says you should check the oil level, and another that says low oil level  .....
is there?  Although in 10 yrs I've only seen the low oil message if I've turned the ignition on mid way through an oil change to check it works!  :y :y :y
(Reason being is that it didn't work when I first got my Senator due to the sensor being coked up with carbonised oil - different set up from an Omega)
