Author Topic: oil  (Read 2770 times)
buzzard
  • Invergordon
oil
« on: 09 November 2010, 21:05:17 »
it may sound daft to you guys but could somebody please tell me what kind of engine oil should i run my miggy on? ive always had deisel motors so i thought id better get the right kind for the miggy. thanks folks [smiley=thumbsup.gif]
Re: oil
« Reply #1 on: 09 November 2010, 21:09:07 »
GM Semi Synth.
£40.89 inc VAT from dealer if you have access to Trade Club
That is for 4 x 5l cans ;)
Re: oil
« Reply #2 on: 09 November 2010, 21:12:12 »
GM Semi Synth.
Why Semi and not fully, out of interest?
Not asking to be an argumentative SOB, honest ;) it's just that I always twitch when I hear 'semi synth' and I wonder why not spend a little extra for fully synth..
Seth
  • South Wales Valleys
    • '99 2.5TD GLS Estate
Re: oil
« Reply #3 on: 09 November 2010, 21:13:34 »
GM Semi Synth.
You're slipping J - the grade is 10-40 ;D
Re: oil
« Reply #4 on: 09 November 2010, 21:15:55 »
GM Semi Synth.
Primary reason for full synth is slightly longer life.
Personally, I'd rather change i little more often, and no point using a more expensive oil.  Regular oil changes with a semi synth is far kinder to the engine than less regular changes with a longer life oil.
Re: oil
« Reply #5 on: 09 November 2010, 21:17:02 »
GM Semi Synth.
OK, General Motors 10/40W Semi Synthetic
Re: oil
« Reply #6 on: 09 November 2010, 21:17:03 »
I suppose I can see that on a non-turbo road car, fair point :)
Kneepad
  • West Scotland
Re: oil
« Reply #7 on: 09 November 2010, 21:17:28 »
GM Semi Synth.
You should enjoy reading this:
http://www.omegaowners.com/forum/YaBB.pl?num=1200997700
Re: oil
« Reply #8 on: 09 November 2010, 21:18:30 »
Depending on the turbo, still valid.  For a diesel, definately. For a high performance petrol turbo, I'd probably change the priorities on life/performance/properties.
Re: oil
« Reply #9 on: 09 November 2010, 21:22:32 »
GM Semi Synth.
I had a feeling that would be a link to one of Guy/Simon/Tim(I think?)'s posts ;) (Incidentally that's where all my oil comes from ;))
Indeed - the MR2 gets fully synth from Opie, changed every 6k and/or after an extended session on track .. but it sees a hard life given it's putting out anywhere between 50 and 100% more power than standard (depending on how far the red mist descendswick gets turned up) with an oil-cooled plain bearing turbo :)
Anyway, I digress - can't argue with the price of the GM oil on the trade club, for sure.
buzzard
  • Invergordon
Re: oil
« Reply #10 on: 09 November 2010, 21:34:26 »
cheers fellas [smiley=thumbsup.gif]
Re: oil
« Reply #11 on: 09 November 2010, 23:30:28 »
The synthetic 5w30 is good stuff too, and about 60 odd quid for 20L IIRC. Worth a try if you can live with a 30 weight oil.
Re: oil
« Reply #12 on: 09 November 2010, 23:37:50 »
That's definitely what I'll put in the Omega soon - not sure I can get away with it in the MR2, but I'll give it a try once I fix the oil pressure & temperature gauges :)
Omega_Dan
Re: oil
« Reply #13 on: 10 November 2010, 12:27:44 »
GM 10w 40 is in mine as recommended by fellow members :y
Mr Hagon
  • South West London
  • RWD and V6; the only way to travel!
Re: oil
« Reply #14 on: 10 November 2010, 22:52:38 »
I thought that 5w30 was the current recommendation from GM these days?
Vauxhall Omega Elite 3.2 Estate (Mar '02) in Star Silver.
