Author Topic: Refusing to fire...  (Read 1216 times)
evilClive
  • Cheshire, Crewe
Refusing to fire...
« on: 11 November 2010, 18:34:30 »
Hoping for some wisdom here...
Literally just (1hour ago actually) came to my new(to me)  '99 Omega 2.5 v6, key in, turned it and the engine happily turns over but not joy on firing and the engine management light is flashing.
When its turning over theres a "ticking" noise from the drivers side of the engine.
I treated it to some new plugs when I bought it and it sounded rough when I drove it from Stoke to Coventry to last weekend but drove fine if not a bit underpowered.
Was told to check the Lambda's so decided to buy some new ones to test out which have only just arrived today but cannot fit till tomorrow afternoon to see if this cures the rough sounding engine.
If not then i guess I'll check the DIS pack? (where ever that is)
But as for it not firing, I'm stumped....
Re: Refusing to fire...
« Reply #1 on: 11 November 2010, 18:37:03 »
Paperclip it :y
« Reply #2 on: 11 November 2010, 18:37:37 »
BTW, dont change parts willy nilly, that will confuse the issue :y
vauxfan2k
  • Western Isles
« Reply #3 on: 11 November 2010, 18:40:05 »
if the eml is flashing as you are cranking over the engine, that will be a problem with the transponder reading the chip in the key. has the key been opened or dropped recently?
« Reply #4 on: 11 November 2010, 19:00:33 »
« Reply #5 on: 11 November 2010, 19:04:41 »
And make sure the chip inside the horseshoe part of the key blade is firmly in position
« Last Edit: 11 November 2010, 19:05:55 by RobG »
evilClive
  • Cheshire, Crewe
« Reply #6 on: 11 November 2010, 19:13:29 »
Not been dropped as I am aware, but I am heavy handed... will check the key and the spare and get back to you guys....
evilClive
  • Cheshire, Crewe
« Reply #7 on: 11 November 2010, 19:20:56 »
Result!
Took the key apart, pressed the chip in and after jiggling the key in the ignition, she fired up :-)
However... still sounds like a V8 lol
« Reply #8 on: 11 November 2010, 20:04:45 »
Result!
Glue it in place. Have you paperclipped it yet
evilClive
  • Cheshire, Crewe
« Reply #9 on: 11 November 2010, 20:10:36 »
Glue, on it :-)
No not yet, have read the thread about it and watched the video's.
Will do it tomorrow and see what needs doing as no doubt something will want sorting.
