Author Topic: Head Light Washer Part No.?  (Read 2181 times)
Road Hog Mad
  • Cheshire
« on: 10 November 2010, 13:17:43 »
Noticed today after the car coming back from having a new bumper fitted that when I spray my wind screen and the bumper washer jets spray the headlights the nearside one just does a pool of water under the car.
Took the headlight off to see whats what.
Looks like an L shaped water bend bracket has been snapped, tried bodging it with some pipe but didn't work, need the part no.
Uploaded with ImageShack.us
mindaz
  • IRL , UK
Re: Head Light Washer Part No.?
« Reply #1 on: 10 November 2010, 15:08:00 »
I think these numbers  ;), these are for Omega facelift
GM09147320 LH
GM09147321 RH
cheers :y
« Last Edit: 10 November 2010, 18:11:19 by mindaz »
Vauxhall/0pel 0mega 2.5 , 2002 , CD
Road Hog Mad
  • Cheshire
« Reply #2 on: 10 November 2010, 18:01:26 »
any pictures to clarify the part no.'s?
thank you.
Boditza
  • Craiova, Romania
« Reply #3 on: 11 November 2010, 06:23:08 »
i get these codes in epc for opel omega facelift
9192883 RH
9192881 LH
Welung666
« Reply #4 on: 11 November 2010, 08:11:09 »
Those part numbers are for the jets themselves, you need the 90º bend part on the end of the pipe and the quick release on the other end by the sound of it.
Boditza
  • Craiova, Romania
« Reply #5 on: 11 November 2010, 08:19:00 »
ic.. anyway i get different codes for opel so mine won't help him :)
Welung666
« Reply #6 on: 11 November 2010, 10:09:55 »
I'm at work so no access to EPC :(
« Reply #7 on: 11 November 2010, 10:14:53 »
Which bit are you on about .. not sure from your description !!
Tell me the relevant "bit" and I'll get you the part number !
mindaz
  • IRL , UK
« Reply #8 on: 11 November 2010, 11:08:57 »
I think he is talking about facelift washer jets, not about mini facelift , like in picture  ;)
Welung666
« Reply #9 on: 11 November 2010, 11:33:35 »
You can't call that a picture ;D ;D (no offence RHM ;) :P )
Clarifying whether facelift or not would help however.
Nige, I took it as the part numbered 3 in your pic as that is a 90º elbow as per the OP's original description.
« Reply #10 on: 11 November 2010, 12:10:11 »
Well if you can tell me where else in the EPC there is any info .. I'll happily look ... but my "version" of the EPC only gives what you see ....
The write up to accomopany that "picture" is :
 1 PUMP, RESERVOIR, HEADLAMP WASHER   -X1999999 90166361 14 52 103 1
  1  PUMP, RESERVOIR, HEADLAMP WASHER  Y1000001-  90508709 14 52 104 1
  2  GASKET, PUMP TO RESERVOIR    90053056 14 52 200 1
  3  DISTRIBUTOR, HEADLAMP WASHER   -X1999999 90039908 14 52 431 2
  4  DISTRIBUTOR, HEADLAMP WASHER   -X1999999 90491297 14 50 686 1
  5  HOSE, 8 MM ID. X 10 M, HEADLAMP WASHER (SOLD BY THE METRE)    90442014 14 52 404 AR
  6  CONNECTOR, HOSE, HEADLAMP WASHER  Y1000001-  90507653 14 52 440 3
  7  CLAMP, HOSE, HEADLAMP WASHER   -X1999999 11088301 20 94 318 AR
  8  CLAMP, HOSE, HEADLAMP WASHER  Y1000001-  90507654 14 52 870 AR
  9  VALVE, NON-RETURN, HEADLAMP WASH  Y1000001-  90507652 14 52 667 1
  10  NOZZLE, HEADLAMP WASH   -X1999999 90510268 14 52 731 2
  11  SPRING, RETAINING, HEADLAMP WASHER NOZZLE  Y1000001-  90508376 14 52 869 2
  12  JET, HEADLAMP WASH, RH, BLACK   -X1999999 90509518 14 52 705 1
  12  JET, HEADLAMP WASH, RH, PRIMED  Y1000001-  9192883 14 52 756 1
  12  JET, HEADLAMP WASH, LH, BLACK   -X1999999 90509516 14 52 702 1
  12  JET, HEADLAMP WASH, LH, PRIMED  Y1000001-  9192881 14 52 707 1
  13  SCREW, NOZZLE TO RADIATOR GRILLE    11085631 20 38 786 4
  14  STRAP, RETAINING, 120 MM LONG, HOSE SET TO CRASH LIMITER, FRONT END  Y1000001-  90381846 12 88 885
Quince99
  • Lincolnshire
« Reply #11 on: 12 November 2010, 00:10:30 »
Any chance of a larger picture please, having trouble making out the numbers? Must be my age!
My jets are basically fine except one is missing the domed top section with the cross shape on top.
