Author Topic: Tracking  (Read 1281 times)
Julian
Tracking
« on: 10 November 2010, 15:55:57 »
I have no idea what the tracking should be, I have replaced the wish bones and the tracking has gone from toe out to toe in with no alterations to other components.
    Just a rough idea would be great as other bits will probably need sorting before its worth setting up probably, thanks.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Tracking
« Reply #1 on: 10 November 2010, 16:21:02 »
as a guide 0-1.5mm toe in but you need to have the cambers checked as well as on a mig tracking is only half of the job
other rides
Julian
Re: Tracking
« Reply #2 on: 10 November 2010, 17:33:59 »
Thanks for info, can now set tracking when I have fixed the tracking machine which is also bust!
henryd
  • west cornwall
Re: Tracking
« Reply #3 on: 10 November 2010, 18:40:04 »
welcome to the forum by the way :y :y
other rides
Re: Tracking
« Reply #4 on: 11 November 2010, 12:41:49 »
Minus 0.10 minutes, plus or minus 0.05 error I believe.
Re: Tracking
« Reply #5 on: 11 November 2010, 12:43:48 »
And yes, don't forget the camber at 1degree 10 minutes.
Re: Tracking
« Reply #6 on: 11 November 2010, 18:34:07 »
But all dependent on getting the rear going straight first :y
« Last Edit: 11 November 2010, 18:34:18 by TheBoy »
Re: Tracking
« Reply #7 on: 12 November 2010, 00:19:01 »
Plus, it's possible to rifle site the front wheels to line up with the back when parked with steering wheel straight ahead. But needs well lubed track rod adjusters to diy.
But all this is only saves the tyre wear on the way wheels in motion, or one of their franchises, of course. It really needs setting correctly.
