Author Topic: Just Got Back From The Garage...  (Read 852 times)
P6UL K
  • Dartford, Kent
    • Vauxhall Omega 3.0 Elite
« on: 12 November 2010, 11:15:49 »
Oh dear, which i hadn't gone now lol
I've not had the car in the air since purchasing from Omegamover about 2 months ago, i've been getting the odd unusual sensation from the suspension while driving so i thought i'd get it checked out..... But a car in the air often reveals other issues  :(
1. Rear doughnut bushes worn
2. Rear brake pads low
3. Rear shocks (self-levelling) leaking fluid of some sort
4. Engine oil leak - pretty much everywhere from the head down, covering the starter motor, sump, gearbox etc...
5. Bald rear tyre
6. Possible rear wheel bearing worn
7. The windscreen has developed a nice 5in crack
I which i'd stayed in bed lol
Anyways, i knew some bits needed doing.... Anyone offer any thoughts on the oil leak?  I'm thinking maybe rocker cover gasket perhaps?
« Last Edit: 12 November 2010, 12:07:49 by P6UL_K »
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Just Got Back From The Garage...
« Reply #1 on: 12 November 2010, 11:19:58 »
oil leak most probably cam covers but only use genuine parts to fix it as the after market stuff is mostly $hite
other rides
« Reply #2 on: 12 November 2010, 14:19:43 »
1. Try going poly, should see good improvment
2. They are only £10
3. Most expensive issue here, £150 pair if you want to keep Self Levelling, you could ditch it and put standard shocks on for £70 a pair. Just pull fuse on the pump
4. CamCovers, easy, if fiddly fix
5. Tyres wear with any car, personally i would replace them in pairs
6. Should not worry too much about that, why is just 'possible'? Could they not tell?
7. Fully Comp, usually has a specific Window Excess, cost me £75 to get a new screen
