Author Topic: 3.2 MV6 CUTTING OUT  (Read 832 times)
WADZ000
3.2 MV6 CUTTING OUT
« on: 13 November 2010, 19:04:35 »
Hi
Just bought a 2001 3.2 MV6 with Autobox. I am having a problem with it cutting out when you go heavy on the throttle. It is fine at idle and when you rev it also if you take it easy it is fine.
I have plugged a code reader in and no fault codes present.
Anyone any ideas?
Cheers
Alan
« Last Edit: 13 November 2010, 19:52:08 by WADZ000 »
Re: 3.2 MV6 CUTTING OUT
« Reply #1 on: 13 November 2010, 19:09:17 »
Do the pedal trick and check for codes would be a sound first step, I reckon: http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
« Reply #2 on: 13 November 2010, 22:33:55 »
Hmmm, is it just the engine cutting out or the whole electric system, might point to a loose battery terminal or similar....?
Anything obvious with the drive by wire plug?
Live data via tech 2 ultimatey?
Just some thoughts... :-/
« Last Edit: 13 November 2010, 22:35:14 by chrisgixer »
