Author Topic: Heater blower not working  (Read 1667 times)
ericn
« on: 12 November 2010, 17:02:13 »
X Reg 2000cc Facelift with climate control Heater blower inop 30amp fuse OK.
omegadti
  • Glasgow
    • omega dti
Re: Heater blower not working
« Reply #1 on: 13 November 2010, 00:25:44 »
Just had the same problem myself - the heater fan motor is fubarred. You can get them on e-bay for £20-£30 delivered.   There are lots of other postings with fitting instructions.   One tip - check replacement fan for broken blades or missing balancing weights otherwise you will get terrible vibration and have to strip down and replace all over again
« Reply #2 on: 13 November 2010, 01:30:43 »
More likely to be the rheostat, just had to replace mine, and seems to be a common problem; there have been a lot of similar posts recently.... :(
omegadti
  • Glasgow
    • omega dti
« Reply #3 on: 13 November 2010, 15:45:38 »
having read all the threads the most common fault is that the scuttle drain gets blocked and filled with water, the water overflows and gets into the fan motor and destroys the bearings or motor or both and the fan stops working.   If you have had wet passenger carpet then some time in the future your fan will pack up - changing it is a cheaper option to any other component on a facelift model.
Welung666
« Reply #4 on: 13 November 2010, 16:57:08 »
I've got a motor and rheostat here if you need one Eric :y
« Reply #5 on: 13 November 2010, 21:00:19 »
I should have taken you up on the rheostat Lee, I had no idea what a new one would cost.... :o :'( :'(
Welung666
« Reply #6 on: 13 November 2010, 21:03:35 »
Why? Did you buy a new one Mike?
« Reply #7 on: 13 November 2010, 21:10:16 »
Cos I was ill and I needed it fixing so put it into a local auto electrician........and said fix it... :y
I also asked them to replace the airbag ecu, he questioned my request I said yes, just do it, till he mentioned that a new one is in the high hundreds.... :o :o I suggested he leave it, he felt I had made the right decision... :D :D
Welung666
« Reply #8 on: 13 November 2010, 21:17:33 »
How much then?
I've got an SRS ECU here too ;)
« Reply #9 on: 13 November 2010, 21:23:37 »
How much then?  Not tellin cos you will laugh at me, labour charge was fair enough though... :y
  Need an ef one Lee, philrich plugged it into to his reader and fault is quite clearly listed and will not clear.......red light on in the car confirms..... ::)
« Reply #10 on: 13 November 2010, 22:36:54 »
Got that here Mike if you still need one :y
« Reply #11 on: 13 November 2010, 23:14:45 »
You got reply to PM and Money.....Thanks.. :y :y
