Author Topic: please help 2.2 auto service  (Read 2739 times)
pjd
  • eastbourne
« on: 06 November 2010, 17:32:05 »
i have just bought a 2.2cd auto and done most of the service including coolant but cannot see how to drain and refill the auto fluid , car started to lose gear in fourth and go into manual mode if i stop and restart the car if works fine
Re: please help 2.2 auto service
« Reply #1 on: 06 November 2010, 17:34:33 »
Supposedly sealed for life, but in reality needs doing every 70-80k
I believe there is a guide in Maintenence Guides, but basically its taking off the autobox sumps.
pjd
  • eastbourne
« Reply #2 on: 06 November 2010, 17:55:00 »
can you tell if the coolant system only having water in it and maybe very old antifreeze would kill the autobox oil has built in oil cooler on the rad
« Reply #3 on: 06 November 2010, 17:55:51 »
Will kill your headgasket
fed up
« Reply #4 on: 06 November 2010, 18:03:23 »
Hi, I have the same car. I've had so much trouble with limp mode etc but sorted it by buying a code reader and understanding the problem. In short the gearbox is sealed but I drained it of oil from the drain plug 13 mm spanner. I then undone the sump gave it all clean up. But I found you cannot top up all in one go. I get as much oil as I can in, without it all pouring out again. I then tighten up the plug start the engine slowly drive half a mile and repeat the process until I match the oil volume Ive taken out. However if you have a preasured pump this may work better. That's how I changed my gearbox oil, and I get smoother changes now.
pjd
  • eastbourne
« Reply #5 on: 06 November 2010, 18:07:51 »
cheers will be my job on suday where is the drain plug
« Reply #6 on: 06 November 2010, 18:09:11 »
Driver`s side of box,
« Reply #7 on: 06 November 2010, 18:11:25 »
Here`s how to check level correctly once you`ve drained it and re-filled. http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
pjd
  • eastbourne
« Reply #8 on: 06 November 2010, 18:12:18 »
cheers looking forward to it the last owner didnt do much to her
« Reply #9 on: 06 November 2010, 18:14:32 »
For peace of mind I`d do a coolant flush & change as well
http://www.omegaowners.com/forum/YaBB.pl?num=1167917774
arthill
  • Greenock
  • HI all pleased to join Forum
« Reply #10 on: 06 November 2010, 18:20:01 »
preferably with proper coolant not water
John
John
pjd
  • eastbourne
« Reply #11 on: 06 November 2010, 19:08:22 »
thats brill i did the coolant change and flush do you know how much oil the auto takes
« Reply #12 on: 06 November 2010, 19:11:03 »
With the sumps off to empty (you`ll still have some in the T/C) app. 6 ltrs IIRC
« Last Edit: 06 November 2010, 19:15:33 by RobG »
pjd
  • eastbourne
« Reply #13 on: 06 November 2010, 19:17:19 »
cheers  im grald i found this site very helpfull
thanks  :D
pjd
  • eastbourne
« Reply #14 on: 14 November 2010, 21:57:47 »
hi just an update took the car to my local garage who looks after my car and mot when he took the front sump off he found metal filings in the oil , the main sump plug was cross theaded as were some of the bolts holding the main sump on i have found a replacement , looked on the parts section but didnt find on is AR25XE
many thanks
pete
