Pages: [1] 2 3  All   Go Down
Author Topic: fitting vectra v6 cam covers  (Read 4198 times)
l.t
« on: 16 November 2010, 14:16:51 »
hi just purchased 2 vectra cam covers for my miggy ... do i need the expensive gaskets or can i get away with the cheapies.... also oil filler is in different place ..do i have to move anything to fit it ?
cheers
ljt
Re: fitting vectra v6 cam covers
« Reply #1 on: 16 November 2010, 14:18:45 »
cheers
ljt
Well all I know is that on the Omega you MUST fit genuine gaskets, with black sealant, or they will soon leak. ;) ;)
Sure it must be the same with Vectra's covers, even though they are metal.
« Last Edit: 16 November 2010, 14:20:08 by Lizzie_Zoom »
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #2 on: 16 November 2010, 14:20:22 »
when I did my cam gakets I used gen VX. They seem to be the only ones recommended on here as the cheapo ones are rubbish apparently, and for a fraction of the price I bet they are!
I've also heard that vectra cam covers aren't advised either, don't know why though, someone else will tell you soon.
TC and BnQ Trade holder.
Dave Elite
  • Ellesmere Port
« Reply #3 on: 16 November 2010, 14:23:41 »
The plastic cam covers on the omega has different gaskets to the vectra metal ones. Make sure you get the right ones.
« Reply #4 on: 16 November 2010, 14:25:44 »
because when your breathers are blocked, the increased pressure will blow your rear crank shaft seal first instead of the cam cover gaskets. Although a rear crank seal is quite cheap, they're a bugger to fit ..... the gearbo has to be removed.  :-?
geoffr70
  • Sunderland
  • Boobies
« Reply #5 on: 16 November 2010, 14:29:00 »
See!
« Reply #6 on: 16 November 2010, 14:30:27 »
pay cheap pay twice, pattern do not last! Geniune gaskets, genuine black sealant, not green
Why the Vectra cam covers? Your better off with the stock plastic ones.
I did my camcover at about 105k miles, with genuine parts, its not leaked in several years and 45k!
Fresh oil and clean breathers prevents the gaskets blowing  :y
« Last Edit: 16 November 2010, 14:33:01 by tunnie »
« Reply #7 on: 16 November 2010, 14:33:52 »
Geniune gaskets, genuine black sealant, not green as per the guide.  ......
I wonder how long orange Loctite  lasts?  ::) ::)
« Reply #8 on: 16 November 2010, 14:38:36 »
Does it smell of oranges too?  :D
How much is it?
Know some people have used various types of Loctite, but i've never had any issues with GM's Black sealant, and as its a job thats done once every 100k or so, i'll stick with it for when the others need doing.
« Reply #9 on: 16 November 2010, 14:59:09 »
The other problem with Vectra cam covers is that they need fitting the wrong way around really, to keep the filler in the correct place, and that means the plug holes won't line up properly putting strain on the leads... Your call, but I'd just use genuine Vx parts and the original covers, unless they are cracked, and pay attention to the low torque value. Mine, like TB's were done about 55k ago and don't leak ;)
« Reply #10 on: 16 November 2010, 17:10:15 »
Not quite, more like silicon  ;)
How much is it?...
Don't know, stores doesn't have a price list .... came from a previous stores  :y  :y
humbucker
  • Cambridgeshire
    • www.irmscherMV6.com
« Reply #11 on: 16 November 2010, 17:26:15 »
clean your breathers regularly enough and you dont need to be buggering about with cam covers. the "MUST fit genuine gaskets" claim isnt strictly true, and the gaskets for the metal cam covers are the same if i recall, as i use them on my cavalier AND my omega(s). obviously any OE part is going to be a better fit but that doesnt mean that ALL pattern parts are crap. autovaux supply some excellent fitting items that work fine. i have had no problem with them since fitting a year ago.
PM with your requests.
Dave Elite
  • Ellesmere Port
« Reply #12 on: 16 November 2010, 19:18:21 »
No, they are different. Vectra B metal ones use different gaskets to omega plastic ones.
« Last Edit: 16 November 2010, 19:20:18 by MV6Dave »
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #13 on: 16 November 2010, 19:49:18 »
He is right :y
Also your filler will be in rather an arkward place when you want to do an oil change ::)
« Reply #14 on: 16 November 2010, 20:45:57 »
Wouldn't be surprised if mine may need changing again soon - they have been off about 3 times since then, reusing same gaskets ::)
Pages: [1] 2 3  All   Go Up
