Author Topic: Buying a 3.2 Elite  (Read 1072 times)
Omega Man
  • Oxfordshire
Buying a 3.2 Elite
« on: 17 November 2010, 19:42:06 »
Im going to have a look at a 3.2 Elite tomorrow. Is there any pointers I should be looking for? :y
Re: Buying a 3.2 Elite
« Reply #1 on: 17 November 2010, 20:08:18 »
On top of the usual checks you would do when buying a car.
I would do the pedal trick and see what codes are stored, if any.
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
You also want to see receipts for a recent cambelt kit change, they need replacing every 40000 miles or 4 years, service history, check inner edges of front tyres for wear, tramlining when driving, cam covers for leaks.
« Reply #2 on: 17 November 2010, 20:16:28 »
Thinking about it some more  ;D Make sure all the doors lock and unlock with the remote and that there are no warnings come up on the GID/CID, check the CD cartridge ejects/plays ok.
Once the football has finished you'll probably get a better response ;D
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #3 on: 17 November 2010, 21:10:09 »
check what the back end feels like when going over bumps and uneven ground. If you feel a bump that seems to travel from one side of car to the other, it could indicate the rear shocks are shot - check for leaking on the shocks aswell. Self levelling ones aren't cheap as i found out!
TC and BnQ Trade holder.
Omega Man
  • Oxfordshire
« Reply #4 on: 17 November 2010, 22:15:08 »
Thanks for the info, I will look at the issues, the cam belt is a must ;D
