Author Topic: Omega 16v 2.2 Auto HEAD GASKET  (Read 1133 times)
deadlydave
« on: 14 November 2010, 23:23:49 »
I've just picked up a lovely dark green metallic 2.2 auto with single point lpg fitted to it. Got nice alloys, full service history, new brakes, exhaust, lower arms ... the previous owner spared no expense by the looks of it.
The head gasket has gone, and my question is, what is the likelyhood that the head is no good on these engines? I've owned a 2.2 16 valve for 3 years and never had head gasket problems, so i'm assuming, if i get the head gasket done along with a few other small jobs like water pump and cam belt while it's stripped down, and get the head pressure tested and skimmed should i be ok in the long run keeping the car?
any thoughts would be appreciated.
Welung666
Re: Omega 16v 2.2 Auto HEAD GASKET
« Reply #1 on: 15 November 2010, 08:07:01 »
It's normally poor coolant maintenance that causes these to fail. You won't know of any damage until the head is actually off. The favourite place for failure is the rear waterway to #4 piston. Will you be doing it yourself?
deadlydave
« Reply #2 on: 19 November 2010, 00:17:59 »
no, I work in the trade but im not a mechanic. I know plenty a couple of which have been vauxhall techs, and they havent let me down in the past. They've quoted me £200 plus i buy the bits an get the head tested / skimmed.
« Reply #3 on: 19 November 2010, 09:57:40 »
Why are my alarm bells ringing ;D ;D
greenman
  • greenock
« Reply #4 on: 19 November 2010, 10:30:42 »
Did my HG 2 months ago.Easy enough job.No problems since.As said use the right Antifreeze in the correct ratio.
mark.adams
  • Cambridgeshire
  • Happy
    • Omega 2.6 V6 Elite
« Reply #5 on: 20 November 2010, 20:18:57 »
I only recently did mine and i'm no mechanic.
Omega 2.6 V6 Elite in Shiny Black
