Author Topic: Getting water out of headlight  (Read 1426 times)
Osprey
  • Redhill, Surrey
  • Drink up. The world's about to end.
    • 01 2.6 Elite saloon
« on: 20 November 2010, 16:58:33 »
Found water in the N/S headlight last weekend - serves me right for washing the car I suppose.
I read in old posts that I should check the rubber bungs and run a bead of sealant around the plastic cover joint.  Fine, but how do I get the water out first?  Can the plastic front be removed in situ or is it a headlight out job?
Or should I just stock it with goldfish and call it a feature?   :)
I feel like a military academy. Bits of me keep passing out.
Re: Getting water out of headlight
« Reply #1 on: 20 November 2010, 17:03:46 »
Feature sounds favourite.  ;D
But headlight out otherwise.
Welung666
« Reply #2 on: 20 November 2010, 19:49:27 »
I'd go for the goldfish myself ;) ;D
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #3 on: 20 November 2010, 20:18:10 »
Depends how much water...It may be condensation, something I suffered from at one time.
I used a hot hair dryer on the outside to "dry" the headlight out THEN drove with my lights on for a few days to further dry the light out from the inside.
That was 8 months ago, problem hasn't returned since.
vauxfan2k
  • Western Isles
« Reply #4 on: 20 November 2010, 20:23:14 »
if its just condensation, bung some silica gel packs into the back of the headlamp then replace the rubber cover, they will dry out the moisture and prevent it returning.
sport
  • Stoke on Trent
« Reply #5 on: 20 November 2010, 22:44:59 »
Hi i used a  hot hair dryer, take out the bulbs then place the drier so it blows in the bulb holes it took me about  45 mins
