Author Topic: Low mpg - engine faulty?  (Read 5754 times)
less
  • Hemel Hempstead
    • 2.6 auto saloon
« on: 18 November 2010, 20:23:51 »
Hi all.
Now, before you all think this should be in the chat section, let me explain.   :)
I met up with Darth Loo-Knee yesterday (Really nice chap. He was kind enough to fetch a replacement auto box down for me as he was passing. Thanks a million Daz)
Whilst we were chatting I mentioned that the mig might have to go as I am between jobs at the moment and just would not be able to afford the petrol as I only average around 20 mpg. The best I ever see is about 28mpg whilst on a run.
Daz is convinced that my cambelt timing must be out (or something equally major) and that I should see 27-28 around town with a run returning well over 30. Now, I must confess that mrs Less and myself enjoy some spirited driving, but no matter what, I do not recall ever getting better mileage. I have had the car since 2004, and had a new engine fitted in 2005 after the local stealers managed to blow up the original.
At Daz'z suggestion (as I'm not the disbelieving type   ::) ) I need to confirm that other 2.6 owners (and I guess other V6 owners) actually do see mpg as reported by Daz. If so, I may well keep the car and get it sorted.
The car seems to perform ok although I've always felt that it is not a particularly smooth engine.
In other words I may or not have a problem, but I would not ignore the opinion of one of the forums finest  8-)
So, I'd appreciate it if other V6 owners would give me some honest feedback - good or bad
Thanks all, Les
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Low mpg - engine faulty?
« Reply #1 on: 18 November 2010, 20:40:30 »
I don't remember saying something equally major, what i did say though was when the timing is out the mpg is effected, also if the multi rams are not working this also effects the mpg.
I think the mpg is low on your car, on a run out of a 3.0 estate we had 35.4 sitting at 75 on the motorway, knocking about 27mpg.
I am pretty sure you will get a list saying something similar   :y
« Reply #2 on: 18 November 2010, 20:48:21 »
Although I have seen mid 30's on a run in my 3.0 auto it doesn't take much to reduce it substantially. Low 20's around town I would think is quite normal.
« Reply #3 on: 18 November 2010, 20:49:13 »
Well.......my experience of mig mpg is as follows. My old prefacelift 2.5 was driven very gently, but with very little motorway type driving. The readout was reset on average about every 3 months. It always showed around 24mpg.
My facelift 2.5 runs on LPG - so that may skew things a bit, but it is driven in the same way on the same roads and has over the last 5 months given the same result - approx. 24mpg.
I honestly dont know how this could be improved on by much without spending a lot of time at steady speed on motorway type roads.
Should add, both cars serviced every 4,000 miles.
geoffr70
  • Sunderland
  • Boobies
    • F/L 3.0 Elite, 3.0 MV6
« Reply #4 on: 18 November 2010, 20:50:39 »
I only manage 20 mpg around town in a 3.0 auto, and 34.7 at 70-80 on the motorway.
I get a surge of power at 4100 revs which would indicate the multi rams aren't working right, but my motorway mpg seems to contradict this.
TC and BnQ Trade holder.
« Reply #5 on: 18 November 2010, 21:52:13 »
Its also worth mentioning that it has been said on quite a few occasions on here that when Daz does a cambelt change in his usual precise and perfectionist fashion, it tends to improve the economy and performance of the car. :y
I might even be tempted to put up with a bit of prick ghastly music and have him do mine next year. ::) :D ;D
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #6 on: 18 November 2010, 22:23:15 »
My 2.5 averages around 23 mpg knocking around here in wet Cornwall, mostly 6-8 mile journeys, I can't tell you what it does on a good run as it has a pikey wind break in tow then. The best I have seen from it is on a run up to Plymouth and back where it averaged about 27 mpg but I wasn't hanging around on the way back and quite a lot of hills on route so I suppose on a motorway run at sensible speed it ought to crack 30  ::)
other rides
2woody
  • Northumberland
« Reply #7 on: 19 November 2010, 08:24:47 »
I currently have five Omegas on the road - 2.6, 3.0 manual and auto and a 3.2. out of these, the 2.6 (manual) is the worst - I've never seen more than 28 out of it, even on a run. And about 25 on my commute
« Reply #8 on: 19 November 2010, 09:54:35 »
Autos are always going to suffer poor MPG in urban.
However, on a steady, long motorway run at a constant 70mph, should easily return mid 30s.
My old 2.5 auto returned about 26 on average on my daily commute, my 3.0 auto about 24 (pre LPG), 3.2 unknown, as I now take a different route due to pointless speed limits.
Boatboy
  • St Albans
« Reply #9 on: 19 November 2010, 10:09:35 »
Can someone show Daz how to change his MID from km to miles :D
My mpg is in line with the op, and the timing was set with great care by the potteries maestro himself and I drive gently most of the time.
In part I put it down to the vastly overcrowded and undulating roads around here where the 2 pedal tango is the norm, but even on a long motorway run to Greece in the summer I hardly bettered 32 mpg, and that was at 60-65 most of the time.
Steve
Every start's a bonus!
03 2.6 Elite estate. Bose my A***
philnohair
  • Didcot, Oxon
« Reply #10 on: 19 November 2010, 14:19:07 »
Mine is a 2.5 auto which I've had for six and a half years and I average 24.2 mpg. I reckon it is around the 20 mark for town work and I have never seen above 30 on a run (90ish is my favoured cruising speed).
At the end of a hard day there is nothing better than slipping into my favourite leather armchair, switching on my BOSE system..........and driving home.
« Reply #11 on: 19 November 2010, 17:09:03 »
Blimey - I've managed over 32mpg from my MV6 over a holiday (1800 miles).  That included some 130mph stints on the French autoroutes ::)
geoffr70
  • Sunderland
  • Boobies
« Reply #12 on: 19 November 2010, 21:03:35 »
Steve
Hello boatboy,  I am intrigued by your trip to greece! Can you give a little more info please as I am intending on going on a huge european driving holiday myself, thanks!
Debs.
« Reply #13 on: 19 November 2010, 21:26:37 »
Recent trip computer averages:
1000 miles of 'day-to day' driving (mixed local/rural/urban runs on B`s and some on A`s, but no motorways): 26 mpg
330 miles (Wirral to East-Kent) only on motorways; in cruise at (slightly more than) legal speeds: 37.5 mpg
millwall
  • se london
  • no muff too tuff
    • accord type s
« Reply #14 on: 19 November 2010, 21:30:34 »
to be honest not really interested in what mpg i get  if it bothered me that much i wouldnt drive a v6 omega :y
