Author Topic: Aux belt length  (Read 2069 times)
MartinP
  • Dudley
    • BMW 320D
Aux belt length
« on: 20 November 2010, 21:27:16 »
This relates to my Robin Hood kitcar build.
I have a 3.0ltr V6 that I have removed the power steering & air con units, I have installed a 45 Amp Bedford Rascal alternator where the steering pump was and now need a 690mm long aux belt.
How long is the non aircon aux belt?
Anyone got a industry book with measurements in?
Any info appreciated.
Martin
Re: Aux belt length
« Reply #1 on: 20 November 2010, 21:53:38 »
If you look at the part numbers on the belts they relate to the length in mm and the number of "poly-v" grooves.
.. So you'll be looking  for a 6PK690 or similar (6 grooves, 690mm). There are a few different schemes. Halfords belts are of the form HB690g (g=6 grooves, etc). Bet to just go into Halfords and find the nearest belt to the size you want.
MartinP
  • Dudley
    • BMW 320D
Re: Aux belt length
« Reply #2 on: 20 November 2010, 22:21:31 »
Thanks Kev,
local Halfords is only down the road  :y
Martin
MartinP
  • Dudley
    • BMW 320D
Re: Aux belt length
« Reply #3 on: 22 November 2010, 23:11:44 »
Sorted  :y
went to the local Halfords, spent 20 minutes looking throught the drive belt guide, then went to the Omega page and the length I thought I was looking for turned out to be 1 metre to short  :-[ :-[
Abandoned the search to return and check the length.
I needed 1680mm not 680mm  :-[, different Halfords near work, 10 minutes of searching turned up a HB1675G belt which fits perfectly.  :)
Martin
Re: Aux belt length
« Reply #4 on: 23 November 2010, 00:17:30 »
I did wonder. I know my Westfield has a 975 on it, and I can't see how you'd get round 3 ancillaries with a belt much shorter.
Glad it's sorted. One step closer. :y
