Author Topic: which fuse?self leveling sus pump 1996,2.5 tdi  (Read 1078 times)
pcd
  • oldham
« on: 24 November 2010, 09:09:32 »
Hi have trIed twice now to change thermostat,but gave up,any advice on that appreciated.Going to replace rear shocks we/nd with standard gas shocks,sacks gas £29 each from euro parts deliverd,BUT WHICH FUSE DO I NEED TO PULL to disconect the pump,i have serched forum with no luck,cheers
Re: which fuse?self leveling sus pump 1996,2.5 tdi
« Reply #1 on: 24 November 2010, 09:14:09 »
FUSE 27 HAYNES MANUAL
PS no need to shout!  ;) :y
« Reply #2 on: 24 November 2010, 10:08:04 »
Fuse 27. It also runs the rear 12v aux socket on elites, or just pull the plug off the pump in the drivers wing.
« Reply #3 on: 24 November 2010, 10:17:58 »
.. or remove the relay from the panel next to the fuse box (it's one of the pair of small ones - the other one being for the main beam).
« Reply #4 on: 24 November 2010, 10:42:22 »
Small relay, top right of the cabin fuse box relay section
« Reply #5 on: 24 November 2010, 10:43:45 »
Even better  :y
