Author Topic: temp guage not working !!  (Read 1344 times)
russ0205
  • northants
    • mondeo
« on: 24 November 2010, 10:43:27 »
Hi can anyone help i have a 2.6 v6 cdx omega and the temperature guage has decided to play up,the car runs fine but the guage only just moves from the stop. the temp inside the car is o k and the car drives o k hoses seem hot under the bonnet oh its an 02 model,
Re: temp guage not working !!
« Reply #1 on: 24 November 2010, 11:05:38 »
The temp sensor is right at the back of your engine in the middle of the V. The sensor you want is the one with a single wire connector to it. You can prove the gauge by touching the connector to a good earth, the temp gauge should then go to fully hot. It could be a dodgy connection or a temp failed sensor although they're ot known for failing. Also, is your dash seated properly? Try pushing the das towards the left where the loom/dash connections are & see if anything happens.
welcome to the forum!  :y
russ0205
  • northants
    • mondeo
« Reply #2 on: 24 November 2010, 14:34:17 »
Thanks for that i have just ran it up the road for about 30 miles seems to be working ??  am at a loss here think i better keep a careful eye on this,yep and ihad a look at where to change the sensor it looks a bit of a fussy job !!!!
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #3 on: 24 November 2010, 14:41:45 »
dont forget that in this cold weather it will take longer to warm up anyway. ;)
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #4 on: 24 November 2010, 15:20:23 »
If I may partly hijack this thread, what will the differences be in curing a cold readout for a '00 diesel?
« Last Edit: 24 November 2010, 15:20:52 by DiamondBlackGeezer »
