Author Topic: dash battery light  (Read 1239 times)
Boditza
  • Craiova, Romania
dash battery light
« on: 24 November 2010, 08:59:37 »
When i turn the key on the car the battery light isn't always present(after i wait a bit the only light is the oil light)... sometimes it light up but more of the times it doesn't. it lights up especially when i drive with consumers on before i turn off the car (rear window heat, headlights) but not every time. is this a problem i should worry about.. what can this be?
p.s. this is without starting the engine so there won't be any mislead users :)
« Last Edit: 24 November 2010, 09:05:08 by boditza »
Boditza
  • Craiova, Romania
Re: dash battery light
« Reply #1 on: 25 November 2010, 06:17:14 »
all of you have the battery light on when you switch ignition?
Welung666
« Reply #2 on: 25 November 2010, 07:23:03 »
The battery light should stay on until it senses a charge coming from the alternator.
Boditza
  • Craiova, Romania
« Reply #3 on: 25 November 2010, 07:27:45 »
then why do you think mine isn't always on when i switch on the ignition?? should it be a problem???
Welung666
« Reply #4 on: 25 November 2010, 07:36:28 »
Firstly try another bulb to eliminate that as being at fault. Then test your alternator using THIS guide :y
Boditza
  • Craiova, Romania
« Reply #5 on: 25 November 2010, 07:45:47 »
i get 13.1v with all consumers on(headlights, climate control, eco off, heated seats, heated window).. i don't think the bulb is faulty because it would light at all :(
Page created in 0.008 seconds with 16 queries.
