Author Topic: COOLANT LEVEL DROPING no apparent leak  (Read 1586 times)
arthill
  • Greenock
  • HI all pleased to join Forum
« on: 25 November 2010, 17:39:18 »
Hi. :-/  My coolant level has been falling for the last few days and the heater takes ages to work, and even then to get normal heat high revs are required, on previous cars i found this to be caused by faulty or sticky thermostat but not sure if this can be the case in the Omega, the fact that heat is eventually coming through suggests to me that the matrix is working, water bottle is still presurising. Any suggestions ??  :-/
John
Re: COOLANT LEVEL DROPING no apparent leak
« Reply #1 on: 25 November 2010, 18:48:09 »
Does engine warm up properly? If so, hbv fault possibly.
If not, check stat,, and locate the leak as well
arthill
  • Greenock
« Reply #2 on: 25 November 2010, 19:07:58 »
Engine warms up normaly and temperature guage shows normal, no leaks apparent unde car and water bottle presureising, would this still happen with a leak or could coolant be vaporising somehow.
John
« Reply #3 on: 25 November 2010, 19:19:09 »
I would be closely looking around the HBV...
Richard A
  • Aldridge, West Midlands
« Reply #4 on: 25 November 2010, 21:40:38 »
Replace HBV with a GM part  :y :y
regards
richard a
richard a
