Author Topic: Frozen driver's door lock  (Read 1614 times)
Evo
  • Amersham
« on: 25 November 2010, 14:55:46 »
My central locking stopped working years ago so I need to use the key to get in. I find the lock prone to freezing up in this cold weather.
I've tried using WD40 but without much success .... any suggestions please as to how I can eradicate the problem?
Re: Frozen driver's door lock
« Reply #1 on: 25 November 2010, 15:02:06 »
WD40 might be OK to initially disperse the water, but you then need something stickier to stay put where you've sprayed it. Try a chain lub.  :y
Welung666
« Reply #2 on: 25 November 2010, 16:04:35 »
Or a PTFE based silicone lubricant :y
mrgreen
  • Salzburg/austria
    • 2000 2.2 petrol estate
« Reply #3 on: 25 November 2010, 16:50:39 »
i believe gun oil is the one as it doesnt attract dirt and wear your lock prematurely also you can buy lock de-icer a squirt of that will clear the lock pretty quick also a good time to be putting a bit of vaseline on your door seals to stop them sticking and getting ripped apart.
Warning: Dates in Calendar are closer than they appear.
Bent valve
« Reply #4 on: 25 November 2010, 18:39:53 »
Try pissing on the lock then wait a few seconds before inserting the key, Works wonders :y
Kneepad
  • West Scotland
« Reply #5 on: 25 November 2010, 20:18:58 »
I assume these words of wisdom are only intended for the male members here.  ;)
« Reply #6 on: 25 November 2010, 23:18:37 »
If not then give me a shout when Lizzie tries it... :D :D :D
Page created in 0.051 seconds with 16 queries.
