Author Topic: V6 & 4 pot calipers compatible?  (Read 1395 times)
V6 CDX-er
  • Sheffield
« on: 22 November 2010, 23:52:23 »
As per the title really.
One of my rear brake calipers is seized, (2.6 facelift), and it seems that I cant find direct replacements from the scrappies for love nor money.
However, one local(ish) to me has two 2.2 Ecotecs and one 2.2DTi in. So does anyone know if the calipers from these are the same, (as in stamped with 42), as the bloke from the scrapyard can't / won't tell me if they are stamped.
Cheers.
hotel21
  • The Kingdom of Fife
Re: V6 & 4 pot calipers compatible?
« Reply #1 on: 23 November 2010, 00:09:21 »
If memory serves, the 2.6 and 3.2 have vented rear discs and thus slightly wider calipers, but happy to be corrected....
« Reply #2 on: 23 November 2010, 00:15:53 »
Yep, and the vented calipers have different piston diameter, so I'm told.
« Reply #3 on: 23 November 2010, 00:22:17 »
One of my rear brake calipers is seized, (2.6 facelift), and .......
Have you tried a grease gun to get the piston moving? It worked on a caliper off my Mum's car.
Don't put your fingers in where the disc would normally live!!!!  :o :o
« Reply #4 on: 23 November 2010, 15:56:57 »
"Don't put your fingers in where the disc would normally live!!!!  "
is there an echo ..... echo echo echo echooooo  ::)  ::)  :y
V6 CDX-er
  • Sheffield
« Reply #5 on: 25 November 2010, 01:51:51 »
Thanks chaps.
Went to the scrappies this morning, and although they had several omegas in, none were V6's. So to that end I can confirm what you have all been saying, and the 4 pots were on solid rear discs, of which the calipers are different. (I know you told me, but I thought it was worth a shot anyway).
I even had a look at a couple of Saab 9-5's, and although the calipers look very simular, they have a different stamp on them.
Cheers anyway chaps.  :y
« Reply #6 on: 25 November 2010, 09:17:14 »
 I can confirm what you have all been saying, and the 4 pots were on solid rear discs,  .....
That's not right, nobody has said that. No idea about 4 pot cars, but all V6s had solid discs until the last few years of production .... 2000/2001? .... which is when they got vented discs. My 3.0 1999 has solid discs
hotel21
« Reply #7 on: 25 November 2010, 19:57:40 »
Its the 2.6/3.2's that have vented rears....  Dunno about diseasels, but doubt it... :y
« Reply #8 on: 25 November 2010, 20:25:52 »
Its the 2.6/3.2's that have vented rears....   .....
It's as simple as that is it?
    • 530D M Sport, 330i Coupe
« Reply #9 on: 25 November 2010, 20:28:41 »
DTi's have solid rears  :y
2woody
  • Northumberland
« Reply #10 on: 26 November 2010, 09:26:19 »
the "42" is the piston size.
having a different size on one side to the other has not been proven to improve the braking in any way !
