Author Topic: Sunroof problem  (Read 2354 times)
Boditza
  • Craiova, Romania
Sunroof problem
« on: 27 November 2010, 17:11:02 »
My sunroof wasn'r working at all and i got from scrap yard a motor and ecu, but its driving me crazy. i tryed to reset it as it was sayd in tis but no luck from the first step.
on the colose position i am supose to push the button untill the sunroof comes to a stand and its completely closed but it doesn't, it tilts up about half way. if i tilt up at max it tilts stays there 2-3 secs(some clicks can be heard) and it comes down about half way of the tilt position. if i turn the knob to full open it opens perfect but when i close it it slides to closed position then opens again :o. it is driving me crazy
this is what tis says
Motor (Gears, Control Unit), Adjust
  Adjust
Ignition on.
Calibration run
1
 Hold preselector switch rotary knob down until motor comes to a standstill. Cover (glass) cover is in closed position.
First
 Learning run
2
 Preselector switch rotary knob to lift – roof tilts.
3
 Preselector switch rotary knob to closed, hold pressed until roof closed.
Second
 Learning run
4
 Preselector switch rotary knob to open – roof opens.
5
Caution
If the roof opens automatically after a closure command (points 3 and 5), repeat points 2 to 5 (1st and 2nd learning runs) by up to three times.
dbr
  • north east.
    • 1997. 2.5CD petrol
Re: Sunroof problem
« Reply #1 on: 27 November 2010, 22:49:22 »
I think its...get fully open. push switch up for 10 seconds. close... push up for 10 seconds.   get to full tilt .....push up for 10 seconds
Boditza
  • Craiova, Romania
Re: Sunroof problem
« Reply #2 on: 28 November 2010, 08:30:20 »
i'll try it then reply back. tx
MutantCav
  • Gainsborough
Re: Sunroof problem
« Reply #3 on: 28 November 2010, 09:30:52 »
Reset is simple...
Push up in full open position for about 7-8 seconds (gives it time to fully open plus about 2-3 seconds)...then 7-8 seconds in the full tilt position then 7-8 seconds in full close position...job done
« Last Edit: 28 November 2010, 09:32:39 by ShieldOfSteel »
Boditza
  • Craiova, Romania
Re: Sunroof problem
« Reply #4 on: 28 November 2010, 16:44:19 »
Reset is simple...
when i open it i keep the button pressed and in 2 secs after it opens completely it starts to close :( and it goes to half tilted pozition wich is basicly its closed position :(
Re: Sunroof problem
« Reply #5 on: 28 November 2010, 16:50:34 »
have you looked at this? ...... it might help  :-/ http://www.omegaowners.com/forum/YaBB.pl?num=1247486519
Boditza
  • Craiova, Romania
Re: Sunroof problem
« Reply #6 on: 28 November 2010, 17:59:09 »
I looked at it and thats what might have ruined my original sunroof ecu.. :( because i didn't knew how to assemble it back  :-[. can you please tell me how do i know i closed the sunroof manualy, i mean what signs should i look for?? what is best to use to manualy close it because i use a flat screwdriver and it doesn't fell like its the right thing.
Kneepad
  • West Scotland
Re: Sunroof problem
« Reply #7 on: 28 November 2010, 19:09:11 »
Yes flat blade screwdriver, push up then turn.
Boditza
  • Craiova, Romania
Re: Sunroof problem
« Reply #8 on: 28 November 2010, 19:23:02 »
i turned but it doesn't seem to have a point to stop when its completely closed to stop turning or something :(
Re: Sunroof problem
« Reply #9 on: 28 November 2010, 19:45:09 »
... but it doesn't seem to have a point to stop when its completely closed to stop turning or something :(
it doesn't, just wind it till it is level with the roof. The stop positions are built into the motor/ecu  :y  :y
Boditza
  • Craiova, Romania
Re: Sunroof problem
« Reply #10 on: 28 November 2010, 20:05:31 »
ok.. thank you for your help with this.. hope i will sort it out eventualy
Boditza
  • Craiova, Romania
Re: Sunroof problem
« Reply #11 on: 29 November 2010, 14:47:40 »
sorted... for further users  take off the mechanism with ecu and motor and press the knob untill it stops then insert it into the sunroof.
Kneepad
  • West Scotland
Re: Sunroof problem
« Reply #12 on: 29 November 2010, 15:39:09 »
Well done.   :y
dbr
  • north east.
Re: Sunroof problem
« Reply #13 on: 29 November 2010, 16:39:48 »
Well done.   :y
:)likewise
