Author Topic: ABS ECU different Manual to Auto  (Read 1088 times)
Varche
  • middle of Andalucia
    • Golf Estate
« on: 30 November 2010, 18:43:48 »
Mine is a Elite 98 model Auto and I am wondering if CDX 99 model manual would be a straight swap?
Is there an issue that needs tech2'ing because of the auto/man aspect?
Thanks :y
Omegatoy
  • UK
Re: ABS ECU different Manual to Auto
« Reply #1 on: 30 November 2010, 19:33:51 »
cant see why should be different abs dont know if ar is manual or auto? as long as the numbers are the same on the abs unit
are the same should be able to just swap them :y
gsizoli
  • Hungary
« Reply #2 on: 30 November 2010, 20:23:36 »
TECH2 is needed to program the ECU to let it manual or auto.My car was converted to manual and it was needed to programming. There will be no error messages but must to reprogram.
« Last Edit: 30 November 2010, 20:25:16 by gsizoli »
Diamond Black Geezer
    • & a silly coupe coming...
« Reply #3 on: 01 December 2010, 00:34:31 »
Had exactly the same issie. You need one with same numbers, engine and gearbox. I know it sounds silly, why the gearbox should affect ABS, but for whatever reason, it does.
Did this recently, and saved a friend a small fortune in tech 2 fees, as we found the 'right' one.
« Reply #4 on: 01 December 2010, 19:00:20 »
Although its the same hardware, there is a software difference that needs a tech2 to sort out...
Varche
    • Golf Estate
« Reply #5 on: 01 December 2010, 19:25:45 »
Thanks , everyone. I will now send mine off to ECU testing in Nottingham and get one refurbed.  :y
Will report back on the experience.
Varche
