Author Topic: What is causing this?  (Read 1472 times)
zuluf
  • Valpovo, Croatia
« on: 30 November 2010, 22:35:06 »
I forget about this all the time and it popped into my mind earlier today. To best describe my question I bumped into this vid on youtube:
http://www.youtube.com/watch?v=BadbjbyUFtI
Sometimes I have a similar problem (it revs from around 1k to 1.5k). It revs and then if you pedal it a bit (or drive) stops and engine acts normal. I tried to narrow down the conditions this appears and its difficult. Sometimes it happens on a moisty day (rain, after rain, fog), sometimes it happened during the summer, cases of winter too.
Mechanic told me that my airflow sensor is faulty but I excluded that after a long read out of different stuff but in the end I did not find a clue to what is the cause of that.
It actually is not a problem, it is more a nagging and irritating phenomenon that I would like to remove if possible :)
Omega B '97 2.0 16v (x20xev) LPG
Thanks in advance
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: What is causing this?
« Reply #1 on: 01 December 2010, 14:55:21 »
does the problem occur on lpg and petrol ?
other rides
zuluf
  • Valpovo, Croatia
« Reply #2 on: 01 December 2010, 16:10:59 »
Can happen on both. First thought that passed my mind was that it has to do something with LPG but it is not. Few months ago I disassembled the air intake part, checked it, cleaned all the hoses, cleaned the throttle valve (used the guide from the forum) because I thought it had to do something with that but no results. Tough I did not clean very much idle control valve and that thingy on it (pic no.23 on the link here)
http://www.omegaowners.com/forum/YaBB.pl?num=1207387811
tango
  • brum
« Reply #3 on: 01 December 2010, 16:18:08 »
you wanna get some carburetor cleaner and clean the idle control valve
i had this problem when i had my 2l gls going back a few years now
zuluf
  • Valpovo, Croatia
« Reply #4 on: 01 December 2010, 22:37:01 »
Ok, I will try it first time I get the chance. Thanks for the info.
