Author Topic: 1 more key prob  (Read 1269 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
1 more key prob
« on: 02 December 2010, 21:29:10 »
 overhaulliing ignition lock,.today i followed the instructions to the letter, laid each brass plungers out and made a note of the sequence. when i finished cleaning everything & i was satisfied when the key was inserted into the barrel it was OK. but the the key will not turn at all. any ideas why  :-/ :'(
Kneepad
  • West Scotland
Re: 1 more key prob
« Reply #1 on: 02 December 2010, 21:38:32 »
If i'm not mistaken, the key does not turn in the barrel. The key turns the barrel.
Did you put the barrel back where it came from to try it?
Abiton
Re: 1 more key prob
« Reply #2 on: 02 December 2010, 21:42:19 »
Did you inspect the inside of the bit on the left in this pic, and remove any burrs that may have been created by failed attempts to turn the key?
raywilb
    • Citroen C4 Cactus
Re: 1 more key prob
« Reply #3 on: 02 December 2010, 21:43:38 »
i was toying with that idea, but then the stop pin could not be put in situ
Re: 1 more key prob
« Reply #4 on: 02 December 2010, 21:44:54 »
sounds to me as though you have a/some tumbler(s) in wrong or wrong order.  :-/
raywilb
    • Citroen C4 Cactus
Re: 1 more key prob
« Reply #5 on: 02 December 2010, 22:52:36 »
i think they ,re right. i did make a note
markspark
  • Bolton
Re: 1 more key prob
« Reply #6 on: 02 December 2010, 22:58:28 »
with the key inserted there should be no brass sticking out past the cylinder it should look like the above photo, if brass is sticking out you have mixed up the tumblers  :y
