Author Topic: crank oil leak  (Read 1096 times)
mr ICE man
  • dolgellau wales
  • if it aint broke try and fix it
crank oil leak
« on: 03 December 2010, 12:17:57 »
the migs been leaking oil for a bit and today after replacing the oil cooler decided to investigate,turn out it the crank oil seal,front,if i were to undertake what looks like a mamoth job do i need to re time everything or can i just take the belt off refit seal etc etc or is the pain in the ass job? :y
scream if you want to go faster!!!
Matchless
  • Nottingham
    • A white van
Re: crank oil leak
« Reply #1 on: 03 December 2010, 13:17:08 »
Cambelt has to come off so need locking & timing kit.
Check your oil pressure sensor is OK and the engine breathers are clear before condeming the front crank seal.
See similar thread here: http://www.omegaowners.com/forum/YaBB.pl?num=1290628831/0#11
Its about time I wrote a guide for this job.
« Last Edit: 03 December 2010, 13:18:24 by Pete »
