Author Topic: would it do this??  (Read 1627 times)
griff2494
  • fallingbostal,germany
would it do this??
« on: 03 December 2010, 16:59:47 »
hi all
would a air lock in the coolant system make the car get red hot realy fast (makes warning light come on)and the coolant tank is bubbling!
also even when red hot the heater just blowing cold air out
cheers
trem
Re: would it do this??
« Reply #1 on: 03 December 2010, 17:04:10 »
if the tank is bubbling like you say and its heatin up fast that sounds like head gasket, just had same thing with my sisters pug 106, thermistat had gone but she kept drivin.
So check your thermostat, i know the cooling system on the omega is a self bleedin system, just make sure it has been filled as directed
griff2494
« Reply #2 on: 03 December 2010, 17:13:31 »
where is the thermostat located?
done a search and cant find any how to do
cheers
« Reply #3 on: 03 December 2010, 17:16:25 »
cheers
Have a look here ......... http://www.omegaowners.com/forum/YaBB.pl?num=1229464812
as thermostats go, it's burried deep in the engine.  :-?
trem
« Reply #4 on: 03 December 2010, 17:17:03 »
have you downloaded the maintenance manual, it tell you in there
andy beat me too it
« Last Edit: 03 December 2010, 17:17:40 by trem »
« Reply #5 on: 03 December 2010, 17:21:33 »
cheers
Not on the 4-pot :P Housing @ the end of the top hose ;)
« Reply #6 on: 03 December 2010, 17:24:53 »
cheers
Follow the top hose down the pass side of the engine & it connects to the thermostat housing, 2-bolt job to remove
« Reply #7 on: 03 December 2010, 17:26:05 »
cheers
Ooops!  :-[ Applogies, I just assumed that it was a V6  ::)
« Reply #8 on: 03 December 2010, 17:26:58 »
cheers
Some of us only own 2/3rds of an engine :D
griff2494
« Reply #9 on: 03 December 2010, 17:27:27 »
thanks everyone i will have a look at it tommorrow :-)
i will also look for that mainianance manual
trem
« Reply #10 on: 03 December 2010, 17:35:11 »
the manual is a sticky on the top of the maintenance guides section.
Good luck
Kneepad
  • West Scotland
« Reply #11 on: 03 December 2010, 19:20:41 »
hi all
cheers
Is there enough antifreeze in the system. These temperatures will soon freeze the coolant if it's a bit on the weak side.
2woody
  • Northumberland
« Reply #12 on: 03 December 2010, 20:53:22 »
yep it sounds like a partial freeze-up to me, too.
