Author Topic: Crunching Noise coming from shocks  (Read 1919 times)
Omega 37
  • Northampton
    • CD 2.2, HP Firenza & TR6
« on: 03 December 2010, 18:25:37 »
There is a loud crunching noise coming from the shocks when I drive over speed bumps. It has started during this cold spell.
Is this normal or are they on their way out????????????
cheers
Paul
Re: Crunching Noise coming from shocks
« Reply #1 on: 03 December 2010, 18:46:07 »
Crunching or more like continuous knocking
vauxfan2k
  • Western Isles
« Reply #2 on: 03 December 2010, 18:54:50 »
check that the plastic guard hasnt come loose and catching when you go over bumps.
either that or maybe something stuck between the springs?
Omega 37
  • Northampton
« Reply #3 on: 03 December 2010, 18:59:42 »
When the wheels hit the bump it crunches as the wheel is forched up. As the wheel drops down on the other side, it crunches again. can't hear it during normal driving.
The noise comes from both front wheels.
I had a crunching noise like this b4, coming from the n/s. Was the steering idler.
£380 for full set of struts/springs & bolts etc from gm (with discount)
cheers for replies  :y
vauxfan2k
  • Western Isles
« Reply #4 on: 03 December 2010, 19:04:08 »
well thats my diagnosis thrown out, as I thought you meant the rear shocks. (didnt say which ones)
Omega 37
  • Northampton
« Reply #5 on: 03 December 2010, 19:09:10 »
good point!!!!!!!! had the rear springs done last week, amazing difference
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #6 on: 03 December 2010, 19:21:50 »
I had EXACTLY the same thing from the front...NOT shocks but wishbones. They were flubbered. Changed the wishbones, problem went away.
Omega 37
  • Northampton
« Reply #7 on: 03 December 2010, 19:50:02 »
Done the wishbones, droplinks in the summer  :)
Kneepad
  • West Scotland
« Reply #8 on: 03 December 2010, 20:00:17 »
Get someone to bounce the front end up and down while you get as close as you can to try and determine where the crunch is coming from.
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #9 on: 03 December 2010, 22:08:50 »
my old cdx saloon did the same, only in frosty weather though. never bothered me tbh. ;)
Omega 37
  • Northampton
« Reply #10 on: 03 December 2010, 22:23:05 »
bounced the car, seems to be the shocks where the noise is coming from.
vauxfan2k
  • Western Isles
« Reply #11 on: 03 December 2010, 22:26:57 »
There are plastic gaiters on the shocks, they cover the shaft to prevent ingress of dirt and water from corroding it, they are probably all split
Omega 37
  • Northampton
« Reply #12 on: 04 December 2010, 00:00:13 »
ok thanks, will get the car in the air & take the wheel off for a good look around.
Well if it stops snowing!!!!!!!!! >:(
