Author Topic: uh oh big leak  (Read 1620 times)
Jaymd
uh oh big leak
« on: 01 December 2010, 18:00:29 »
my gearbox is leaking rather badly now it looks like its coming from the join between box and engine can anyone help? i know the breather is leaking and i will be attemting to do that tomorrow snowing or not but could this oil be from the breather too? its a kinda pinky/ browny colour?? plus whats the best way to clean the oil off from under the car :(
Kneepad
  • West Scotland
Re: uh oh big leak
« Reply #1 on: 01 December 2010, 19:58:54 »
Sounds like transmission fluid. It's the right colour.  :(
« Last Edit: 01 December 2010, 20:01:21 by Kneepad »
Jaymd
Re: uh oh big leak
« Reply #2 on: 01 December 2010, 21:44:32 »
thanks thats what i thought any ideas how to stop it lol and also how to remove whats leaked all over the bottom of the car :D any advice will be much appreciated.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: uh oh big leak
« Reply #3 on: 01 December 2010, 22:20:30 »
If the fluid is indeed leaking from inside the bellhousing then it will be gearbox out job to sort, best to clean away as much oil as you can to be sure where it's coming from. Brake cleaner is good for this as it will evaporate and leave the area dry
other rides
Jaymd
Re: uh oh big leak
« Reply #4 on: 05 December 2010, 21:48:09 »
thanks for all your help guys i have acomplished the breather tube change and the throttle body clean today. i have changed the oil and used some of the lifter treatment recomended in some of the posts for the engine noise BUT i still need some help. i bought new sparks for her and wen i took off the coil pack the holes for the plugs were absoloutley full of oil compeltly covering every plug :S confused me a little how she was still sparking but i have cleaned it out and replaced the plugs any ideas how it got there and what i can check?
millwall
  • se london
  • no muff too tuff
    • accord type s
Re: uh oh big leak
« Reply #5 on: 05 December 2010, 21:56:55 »
cam cover gasket
rossi123
  • St Helens Lancashire
Re: uh oh big leak
« Reply #6 on: 05 December 2010, 22:16:16 »
i had same problem and it was cam cover gasket.
Jaymd
Re: uh oh big leak
« Reply #7 on: 05 December 2010, 22:24:04 »
ok guys thanks :D ill report back when the job is done :)
Kneepad
  • West Scotland
Re: uh oh big leak
« Reply #8 on: 05 December 2010, 23:21:15 »
Make sure to use genuine GM gaskets.   :y
Re: uh oh big leak
« Reply #9 on: 06 December 2010, 10:02:32 »
And clean the breathers out ;)
