Author Topic: Tailgate lock barrel  (Read 1671 times)
mrjimbo
  • Oxfordshire
« on: 04 December 2010, 00:04:09 »
How does the tailgate lock barrel come out ? do you have to remove the complete number plate light and the whole lock assembly or is it a bit easier than that ?
Kneepad
  • West Scotland
Re: Tailgate lock barrel
« Reply #1 on: 04 December 2010, 00:13:19 »
Remove trim panel, disconnect central locking linkage, undo nuts then unhook the cylinder assembly.   :y
mrjimbo
  • Oxfordshire
« Reply #2 on: 04 December 2010, 00:22:15 »
So it comes out from inside the tailgate then, wasn't sure if i needed to remove the numberplate light/handle assembly   :y
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #3 on: 04 December 2010, 09:42:42 »
So it comes out from inside the tailgate then....
It makes it harder for the thieves to get in! :y
Kneepad
  • West Scotland
« Reply #4 on: 04 December 2010, 14:26:04 »
mrjimbo
  • Oxfordshire
« Reply #5 on: 07 December 2010, 13:19:30 »
Can the barrel be stripped down and reconfigured to suit a different key or do you need to get another barrel to suit the key ?
zirk
  • Epping Forest
    • 3.2 Manual Special Estate
« Reply #6 on: 07 December 2010, 14:18:15 »
The levers will be different, ie fitted by lever number and sequence to each key, so no, best to source an auto locksmith place if you want to retain the same key.
Chris.
mrjimbo
  • Oxfordshire
« Reply #7 on: 07 December 2010, 19:09:21 »
OK we'll forget that idea then   ;D
