Author Topic: Wheel rim band and transmitter  (Read 2787 times)
rob in gib
  • Plymouth
    • Jaguar S type 3.0
Re: Wheel rim band and transmitter
« Reply #15 on: 07 December 2010, 21:50:37 »
just to clarify
they are indeed pressure sensors
these were the first generation supplied by smartire based in newbury
and yes there is a counterbalance fitted opposite the sensor
these were a requirement when fitting run flat tyres such as Goodyear emt
so yes would have been fitted to several police cars
just for info the second generation sensors were mounted to the base of the valve and the third generation are now biult into the vehicle and uses the abs sensors to detect differences in rolling circumferences
hth :y
just noticed your photos this sensor was fitted to the nearside front ID3  and yes there would have been a display inside the vehicle these sensors also measured temperator as well as pressure
« Last Edit: 07 December 2010, 21:57:26 by rob_gib »
Just chilling in the sun. I wish back in the rain like everybody else
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #16 on: 07 December 2010, 21:54:52 »
just to clarify
hth :y
Interesting that they were 'requirement' when fitted to Run Flat Tyres.
Kind of defeats the object.  ;D
« Last Edit: 07 December 2010, 21:55:14 by Broomies_Mate »
rob in gib
  • Plymouth
    • Jaguar S type 3.0
« Reply #17 on: 07 December 2010, 22:00:39 »
the reason behind the requrment of the sensors was Goodyear EMT tyre could be flat without a notice to handling or visual signs but a flat tyre would wear the shoulders of the tyre very quick
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #18 on: 07 December 2010, 22:02:05 »
Would that be because they felt flat even when inflated?  ;D
Abiton
« Reply #19 on: 07 December 2010, 22:02:45 »
...the third generation are now biult into the vehicle and uses the abs sensors to detect differences in rolling circumferences...
Eee that's proper cunning, that.   8-)
2woody
  • Northumberland
« Reply #20 on: 07 December 2010, 22:12:48 »
in the USA it was a kneejerk reaction to a number of SUV pressure-loss crashes
