Author Topic: Wheel rim band and transmitter  (Read 2789 times)
ianu
  • Oxfordshire
    • XC90/Maserati QPV/CooperS
« on: 06 December 2010, 21:04:58 »
Hi all,
Just swapped my alloys over for a set of steel rims and tyres for the winter. I'd purchased the steels from another forum member in preparation back in the summer (no problem - but obviously had no history of their former life - still no problem). However - whilst having the tyres fitted - on (inside the tyre effectively)  two of the four rims was a jubilee band holding a transmitter device about the size about 3 - 4 inches long and an inch high. I've had them removed and wondered if anyone knows what they would be for and if they were for a particular spec car. My thoughts are they are probably tyre pressure sensors of some sort and I can only think that 'plod' cars might have used them. Anyway I have 2 spare if anyone can find a use for them (I obviously have no idea what they would transmit to or if they work)  :-?
By the way - I buffed up the hub caps, removed the centre badges to paint red behind them, polished the badges and re-secured and d'you know what - it looks the muts. I'll get some pics when a) the weather is warm enough to let me wash the rest of the car - but the wheels look fantastic.. :y
Cheers
Ian.
mrjimbo
  • Oxfordshire
Re: Wheel rim band and transmitter
« Reply #1 on: 06 December 2010, 21:12:18 »
Have you got any pics of the bands that came from inside the tyres/wheels, i'm very curious as to what they might be for   :o
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #2 on: 06 December 2010, 21:18:19 »
Tyre Pressure sensors are a fair bet.
Potentially a very accurate speed measuring device?
Very intriguing!
Abiton
« Reply #3 on: 06 December 2010, 21:18:52 »
Flux capacitors, fo' sure.
That's two point forty-two gigawatts of power you've just lost.  :P
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #4 on: 06 December 2010, 21:34:14 »
I cant believe the advice some people on here give.
Everyone knows Flux Capacitors were only fitted to DeLoreans.
So Stupid!  :(
2woody
  • Northumberland
« Reply #5 on: 06 December 2010, 21:54:57 »
yes - tyre pressure transmitters.
now a legal requirement in the USA and available in the aftermarket here, as well as on new cars.
ianu
  • Oxfordshire
« Reply #6 on: 06 December 2010, 23:35:48 »
..thought they might be .. I'll get some pics up later in the week - they're still rattling around in the boot at the mo. I'm intrigued why they'd be on a set of steel rims that are most likely off a lower spec model - 205/65/15's - is the tyre size I've just fitted to them to replace what was on there. Does anyone know if 'plod' cars had pressure sensors fitted ?
ianu
  • Oxfordshire
« Reply #7 on: 06 December 2010, 23:43:57 »
Hi mrjimbo - yes these were the rims you gave me - I'll keep you posted. You don't happen to have a redundant tyre pressure display lying around in your car do you ??  ;D
ianu
  • Oxfordshire
« Reply #9 on: 07 December 2010, 20:48:52 »
Ok - here you go. I have heard some theories about how these work - but I'd still expect 4 to be fitted and there to be a receiver in the vehicle. Anyway according to their website - they no longer do these for 'automotive' use. I'd still love to know if the plod fitted them.
http://www.smartire.com/company
Here are the pictures:
One is obviously a transmitter - but not sure what the other one does - but I believe that these work by comparing relational speed of the wheels to each other rather than actual pressure. So a drop in pressure affects it's speed with respect to the others - I think  :-?. But you still need to send the information to a visible receiver somewhere don't you.
Why only 2 ? - I have no idea if these were on the same axle or front / rear - Mrjimbob do you know any history of these wheels whilst in your posession or prior to that ??.
Next time you're having tyres fitted - it's impossible for the fitter not to know these are on the rim because it's a  :-X to get the tyre over the top of them to get it off.
There you go - a mystery  :y
Cheers
Ian
Broomies Mate
  • Bristol, UK
    • Stuff!
« Reply #10 on: 07 December 2010, 20:53:36 »
I'm guessing not just a barsteward to get the tire over the rim, but also a complete git to balance the wheel too.
ianu
  • Oxfordshire
« Reply #11 on: 07 December 2010, 21:22:16 »
..not 'alf - there were some big b***er weights on the rim - but if you look at the steel band there are some counter weights threaded on the banding that were on the opposite side of the rim whilst they were fitted..
« Reply #12 on: 07 December 2010, 21:25:11 »
Lol at the freebie plastic vernier from one of the elecronics magazines a few years ago.
mrjimbo
  • Oxfordshire
« Reply #13 on: 07 December 2010, 21:34:53 »
I seem to remember that the 2 rear tyres had more balance weights than the front and it did have a slight balance problem on the rear wheels that the tyre fitters could never seem to cure i eventually put it down to the propshaft.
I can see why they couldn't get it right   ;D
« Reply #14 on: 07 December 2010, 21:44:16 »
Looks like it should be strapped round the neck of a bear as a tracker!
